Do I need an amp for my LSi9's?
Okay, I just sold my New In The Box CSi5 on ebay and had to eat about $40 bucks..not too bad. StopherJJ1980 good idea on the "Buy it now" thanks! I apologize if I were a bit over zealous with trying to sell it here on CP, I really didn't know the proper etiquette and I really needed to sell the CS before I could buy the LSiC. I do appreciate everyone who had constructive critisim to give me regarding the topic. Okay, enough of that. I am still in the same boat with my receiver. Right now I have a Yamaha HTR 5990 to go with my current speakers.
Lsi9's front
Lsi-C center (on the way)
Lc 80i rear ceiling
Psw 1000 sub
Several members suggested keeping the HTR 5990 and perhaps using it as a preamp.
question? What brand/ model of amp would be good to drive those Lsi9's and perhaps the center channel as well.
Or would a more powerful rated receiver be a better route??? name and brand would be appreciated.
Lsi9's front
Lc 80i rear ceiling
Psw 1000 sub
People who think they know everything, really annoy those of us who do.
Post edited by Ised8u on
I would say stick with the yamaha and use it as a preamp. I'm not really sure on what amp would go well with the 9's, but people around here seem to go with brands like outlaw (the $200 monoblocks are popular), nad, rotel, adcom and some others. I'd think that trying to go the seperates route would be better but might be a bit heavier on your wallet (unless you stick with the yamaha as a pre/pro).
Hope that helps a little... -
I bought the Adcom 5 channel model 7000 used. Haven't had anymore problems. The Yamaha works fine as a pre-amp.Jgladden
Yamaha RX V2200
Adcom 7000
Polk LSiC
Polk LSi9
Polk 404 Sub
Polk LSIFX
Sony 55" LCD HDTV -
Congrats. Outlaw, Rotel, Parasound, ect. All are good. If you can swing a 5-7 channel amp that would be best since then you would be totally covered & it would save you from upgraditis for more later on! Maybe! LOL
Whatever amp you get, you should not get less than 200 watts!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Ised8u wrote:Okay, I just sold my New In The Box CSi5 on ebay and had to eat about $40 bucks..not too bad. StopherJJ1980 good idea on the "Buy it now" thanks! I apologize if I were a bit over zealous with trying to sell it here on CP, I really didn't know the proper etiquette and I really needed to sell the CS before I could buy the LSiC. I do appreciate everyone who had constructive critisim to give me regarding the topic. Okay, enough of that. I am still in the same boat with my receiver. Right now I have a Yamaha HTR 5990 to go with my current speakers.
Lsi9's front
Lc 80i rear ceiling
Psw 1000 sub
if you want to stay with the receiver option i HIGHLY recommend the yamaha rxv2600. the htr line that you bought is the "b" line yamaha product, while the "rxv" is the main line. think toyota/lexus. this receiver has many great features, MORE than enough power to drive your lsi system, and while others may recommend the amp/preamp solution, this may be cheaper and you yourself may not be able to tell the difference. i guess it all depends on what you can get back from the 5990. check my sig for what i am running and it performs VERY well. i get compliments all the time on how good everything sounds. the room i have it setup in is about 20 wide by 12 deep. not too big and the system does an awesome job.Jeff Rowland CAPRI | Yamaha RX-V3800 | Jeff Rowland Model 6 Mono Blocs | Technics SL1200 MKII | Shure V15VxMR w/ JICO Stylus | Sony SCD-XA5400ES | Monster HTS 2600 | Polk Audio LSi 15 w/VR3 Fortress Mod | REL T/9 x2 -
at least get amplification to the 9's to start if the budget is tight. can go with used 2 channel amps (assuming that reciever has pre outs.)
As mentioned, the outlaw mono's seem to be a great bang for the buck. 325 each new 300 watts into 4 ohms, not shabby. I will be getting 2 of them used and will post my impressions down the road.
I am a personal fan of Rotel amplification, but there are a lot of parasound lovers out there too. just some names, especially if you go the used route. Try to shoot for AT LEAST 200 wpc into 4 ohms. lots of used listings only have the 8 ohm rating, but if you search online or check with us, you can get the 4 ohm ratings.
for example, I have a Rotel RB980 that is 120 WPC into 8 ohms, but 200 WPC into 4 ohms.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Amplified it............
I suggest Carver amps.........for a tight bugetGodspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
I agree with the whole 'don't go under 200w idea.'Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Those Outlaw monoblocks are $325...I am considering getting 2
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
