my $100 banana plugs wont fit??
ronnie
ronnie Posts: 150
know i know monster cables are not highly regarded here, but i bought 2 pair of Monster Cable ULTS1000MT-10/10, 100 bucks each....the banana plugs wont go in far enough into my adcom....should i cut the plugs off the end and try to bare wire it or buy regular 14 gauge wire and be out 100 bucks....they fit snug into my reciever.......what im really worried about is vibration making them come out
Yamaha RX-V2600
Adcom GFA555 x 2 :D
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Post edited by ronnie on
  • Willow
    Willow Posts: 11,219
    edited March 2006
    I say return the damn cables and buy some others
  • danger boy
    danger boy Posts: 15,722
    edited March 2006
    banana plugs don't always fit in all the way. and long as it's a snug fit and doesn't fall out. the banana plugs should be ok.
    PolkFest 2012, who's going>?
  • ronnie
    ronnie Posts: 150
    edited March 2006
    its not snug at all ...a little pull and they come right out
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • ronnie
    ronnie Posts: 150
    edited March 2006
    the adcom has the right terminals for the banana plugs but they just wont fit in ...
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • Shizelbs
    Shizelbs Posts: 7,433
    edited March 2006
    Are they the ones with the screws in the back of the plug?
  • ronnie
    ronnie Posts: 150
    edited March 2006
    no. i dont think so..im really not sure
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • ronnie
    ronnie Posts: 150
    edited March 2006
    i think there all one piece
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • danger boy
    edited March 2006
    maybe your speaker can't use banana plugs.. some look like they can, but won't.
  • ronnie
    ronnie Posts: 150
    edited March 2006
    my polks are fine, the plugs fit perfect in them ...they just wont fit right in the adcom amp
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • george daniel
    george daniel Posts: 12,096
    edited March 2006
    + 1 what model adcom?
    Oops, saw the model in you sig. line,, I had a 555 and purchased some monster speaker cables, about 2 years ago,, took em back,,and replaced with signal cable,bananas on both ends,, no problem,good fit, good solid cable.
  • unc2701
    unc2701 Posts: 3,587
    edited March 2006
    I've had issues with my 555's posts, too. The cobalt locking bananas work great, but I might just try to replace the posts instead...
    Backburner:Krell KAV-300i
