Using Banana Plugs
kenhiltz
Help again!! I'm still trying to connect my new LSI speakers. In the owners manual it says " To use Banana Plugs ( US Only ) ??? I just bought 5 sets at $20.00 per set, Why can't I use them here in Canada??? or am I miss reading something in the manual???
I think this same message is posted some where else in the forums. Sorry this is new to me.having trouble figuring out how to start a new thread.
Post edited by kenhiltz on
kenhiltz wrote:Help again!! I'm still trying to connect my new LSI speakers. In the owners manual it says " To use Banana Plugs ( US Only ) ??? I just bought 5 sets at $20.00 per set, Why can't I use them here in Canada??? or am I miss reading something in the manual???
The "US only" term refers to the plastic plugs that are used to plug the holes in the binding posts. Just remove the black and red plugs and you are ready to use the banana plugs. Banana plugs, bare wire, spades... these are all just different connections to the binding posts. They will all work with your speakers.
I'm guessing that US only delivered LSi have the plastic plugs or something installed from the factory.
Get them things hooked up and happy listening.
