Speaker wire quiestion?
acstech
I am replacing my speaker wire from 16 to 14awg. The wire I purchased does not clearly mark which side is positive and which side is negative. I am assuming the side with the writing is positive and the side that is blank is negative. Is this correct? Do you think I will hear any difference in my speakers or will I just convince myself there is a difference because of all the time and money? I would imagine that if I am going to hear a difference it will be when I do my rears since they are a much longer run. Thank you for all your help.
Polk Monitor 50's (fronts)
Polk CS2 (center)
Polk Monitor 30's (rears)
JVC 100W sub (being replaced)
JVC 550w Receiver (being replaced)
xbox
32" Sharp
Polk CS2 (center)
xbox
32" Sharp
Post edited by acstech on
Just make sure that you match from the amp,to the speaks,EX: wire with lettering (pos from amp--to pos. to speaks), red= red,,black= black:)JC approves....he told me so. (F-1 nut)
Thank you! Thats what I did be before.Polk Monitor 50's (fronts)
Polk CS2 (center)
xbox
32" Sharp -
Yes. I install mobile audio/video equipment for a living and that is correct.
