matching the rears to the fronts all that important
ronnie
ronnie Posts: 150
edited March 2006 in Speakers
i have RTi12's front ,csi3 center, acoustic research 12in sub, but my 4 rears are yamaha ns-125, they seem to do the job but would it make a noticable difference with RTi4 or the FXi3. THANKS FOR ANY HELP.
Yamaha RX-V2600
Adcom GFA555 x 2 :D
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Post edited by ronnie on
  • louhamilton
    louhamilton Posts: 209
    edited March 2006
    I was in a similar situation as you. I purchased a pair of RTi4's and a CSi3 for my front stage. I kept my Sony satellites as the surround speakers.
    Recently, I purchased a pair of FXi3's to replace them. It is night and day. For example, I tested this with Top Gun. As the jets flew from the back to the front or vice versa, the old configuration became very tinny and you could hear the difference between the old and the new FXi3's.
    Now keep in mind that before I did the A/B testing with the two, I did not notice this difference. However, after doing the test, I would never go back and am now a strong believer in matching speakers.
    -Lou
  • amulford
    amulford Posts: 5,020
    edited March 2006
    It depends on how critical you are. To some it may not be that important. IMHO, I wouldn't have it any other way.
    On the better soundtracks, there is alot of front to back action, you will notice the difference when they match. If you listen to multi channel music, it's a must.
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    edited March 2006
    Yes..There are a big difference. Yamaha speakers have superior quality than Sony, Panasonic, Pioneer, JVC (all the comercial brands) but compared to the "speaker brands" is very inferior.
    If you buy a RTi4 or FX's for surrounds...you could feel the bigest difference. Try it. ;)
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • ronnie
    ronnie Posts: 150
    edited March 2006
    thanks alot...just needed some expert advice before buying the rears ....now its time to save up some cash
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • aaharvel
    aaharvel Posts: 4,489
    edited March 2006
    what lou said.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • janmike
    janmike Posts: 6,146
    edited March 2006
    Like the man said, it all depends on your ears. Worked for me.
    Michael ;)
    NORTH of 60°
  • amulford
    edited March 2006
    Hey, I just noticed where you are. No sh!it... I'm in Swedesboro.
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    Yeah, get rid of those Yammies.
    BTW, you'll get an even bigger bang for buck by upgrading the sub to Hsu or SVS.
    "God grooves with tubes."
  • RichterCAG
    RichterCAG Posts: 70
    edited March 2006
    yes, matching fronts with rears is key. Perhaps not nearly so much as center with fronts, but a tonal match is important.
    For instance, my system is currently comprised of rti10's and 2 r50 for surrounds. Using the Last of the Mohicans DTS sound track quickly uncovers a major tonal imbalance.
    JVC 61FN97
    Harman Kardon avr330
    RTi10 l/r front
    CSi5 center
    Atrium 45 (four for the surrounds.)
  • aaharvel
    edited March 2006
    the only speakers i have that are matching standouts are the fx300i's. They do use a silk dome like the newer rti's, but they're 3/4" instead of 1". When put to the test, the 300's sound nearly identical with the rest.
    If you have to use different speakers for any given position, then the rear surrounds in a 7.1 setup might be ok. Even in a 5.1 setup, all speakers need to timbre match.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • ronnie
    ronnie Posts: 150
    edited March 2006
    thats cool amulford.......whats up neighbor
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • mantis
    mantis Posts: 17,561
    edited March 2006
    If money is the only reason not to have matcing rears, then save and get the right rears down the road.
    I don't like mis matched systems. Nothing more I hate when the rears have a different tone. It's distracting when it's way off. In some systems, different rears aren't as noticable. When you use 2 brands that are close in sound quality, you can get away with it. I have done systems with Polk rears and Boston fronts and it wasn't as bad as one would think. Actually unless you listened to something that moved around the room, you didn't really notice. But in this case, all the speakers where of the same quality just from different companies.
    But there is no reason to own miss matched speakers in a home theater system. Why do it when the goal is to get the most out of the money you spent?
    Dan
    Dan
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2006
    I used to have LSIs in the front, RTi100s as surrounds and Fxi30s as rears. Now I have LSi all around and it is a beautiful thing.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • *Seby*-Polk-
    edited March 2006
    Also, is important the room dimensions (and the bucks :D !!!)
    I have a small room and put Monitor 30 for surrounds and works great. Obviously, the FX's line is far better, but far expensive !!!! (maybe in the future I upgrade my system for FX's and RTi's .... :cool: Anyway, i very Happy with "Monitor Series" !!!!)
