Polk/Momo Remote Bass Gain Module
lollypop7
I just received my Polk Bass Module for my polk C300.2 amp. After I hook it up what should the settings be set to on my amp. I am using both channels to power 2 12" Infiniti 1230w subs individually. Should the gain on the amp be set to "0?" Anyone else have one of these installed. No sub control on my amp. RCA's are hooked up to my HU's rear output. Thanks for any help!
Post edited by lollypop7 on
from the manual, page 12: "Set GAIN to max when using the remote [bass module]"It's not good, very fundamentally simply not good. - geolemon
Where can I get a bass module? I bought the 500.1 used and the guy didn't include it in the box.
I think they are $25 at crutchfield. Just look for the amp, then click accessories tab.
Sweet, thanks man
are all gain modules the same? I mean, do they have the phone cord-looking connector? (RJ-11, I believe) If so, I'll sell you my HiFonics bass gain module that I've never used, for half what they're asking.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
I would not imagine they are "all the same" -- while 99% of them use telephone cord as a hookup, that doesn't mean that the internals are the same... The remote bass gain is simply a remote attenuator for your gain.
That's why you set the gain to "100%" when using the remote module... the little knob lets you dial it down from 100... so that 50% on the knob, is 50% gain. or about that. if you set the gain for 50% on the amp, then 50% on the knob would be 0.5 * 0.5 = about 1/4 gain.
anyway - that being said... it's probably nothing more than a potentiometer, but the values and range for each company are probably vastly different.The Artist formerly known as PoweredByDodge
