Onkyo Setup Help Needed!!
reubenray
reubenray Posts: 91
edited March 2006 in Speakers
I now have my Onkyo 703, the Polk speakers and the SVS sub. Have not been able to find a setting on the receiver to make the speakers small. Does it do this automatic when I use the speaker setup?
If not where is the setting at on this receiver?
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
  • phipiper10
    phipiper10 Posts: 961
    edited March 2006
    I can't say it's exacly the same, I have the 901, and you have to go:
    advanced menu-> speaker set up-> speaker config
    You can then adjust large or small.
    Good luck, enjoy!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • reubenray
    reubenray Posts: 91
    edited March 2006
    The 703 does not have an advanced menu, but it does have a speaker configuration. There is nothing is this section that specifys small or large.
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • reubenray
    reubenray Posts: 91
    edited March 2006
    I also just found out from another forum that by setting the crossover at 80hz sets the speakers up as small.
    Is this correct?
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • DC80
    DC80 Posts: 11
    edited March 2006
    I have have the 803, and it does not have an exact menu were you can specify large or small. The 703's automatic should specify the size of your speakers. I have a pair of rti10's, and it puts those to full band which would be considered a large speaker. I had last years model nr-801, and that let you specify the size of the speaker.
  • TheReaper
    TheReaper Posts: 636
    edited March 2006
    In the advanced setup, speaker configuration, where you can set the crossover individually for front/center/surrond/surrback speakers.
    Setting a crossover for a speaker, is the same as on other receivers as setting the speaker to small (bass below the xover is sent to the subwoofer instead of the speaker).
    If you set the crossover for a speaker to full band, that is the same as on other receivers as setting the speaker to large (bass from the speaker is not sent to the subwoofer).
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
