cable clutter
krabby5
krabby5 Posts: 923
How do you all keep the area behind your entertainment center neat? I have cables running and intertwining everywhere..
Is there a product that I don't know about to help? Or is it as simple as using tie twisties?
Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
Post edited by krabby5 on
  • Willow
    Willow Posts: 11,233
    edited March 2006
    by allowing the dust to form an even layer which will camouflage the cables!!;)
  • Pablo
    Pablo Posts: 723
    edited March 2006
    I built cable channels into my center. Everything goes through the post that hold up the shelves. It's a pain to move stuff, but it looks better.
    I used to use twisties, so you can do that, or check the hardware place (home depot) for some flexible electrical conduit. They should have some that is split, or you can split it yourself.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • janmike
    janmike Posts: 6,146
    edited March 2006
    And what colour is that dust in Ottawa Willow?
    Michael ;)
    NORTH of 60°
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    Heaven to betsy, that anything electronic might have a wire attached to it.
    Just get the wires seperated by type, do your best to keep the power cables away from the others. There are many types of wire ties on the market, from inexpensive plastic to velcro wraps at www.partsexpress.com. Wire management takes a bit of work and little practice, just take your time, I was once very very convinced that my wire be so neat and orderly, now, eh, it is not that big a deal.
    RT1
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2006
    I use exact lengths and simple velcro.
  • Willow
    edited March 2006
    It has recently changed to Conservative crap color....;)
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    It's an endless battle. Just surrender.
    "God grooves with tubes."
  • unc2701
    unc2701 Posts: 3,587
    edited March 2006
    Last time I cleaned mine up I had about four "orphans"... they weren't connected to anything. Now I use velcro, cable clamps and try to buy cables that are actually the length that I need.
    Backburner:Krell KAV-300i
  • Skynut
    Skynut Posts: 2,967
    edited March 2006
    I zip tie each set together.
    Power wires are zip tied together. Input wires are together. Output wires are together. Speaker wires are together.
    They are sperated from each other but they are together.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Willow
    edited March 2006
    you could always try flexy-tube. I did for a while but when moving my stuff around a lot it was more a pain than anything else
  • louhamilton
    louhamilton Posts: 209
    edited March 2006
    I use runs of the black Flex-tube. I try to keep power cords on once side of the unit and video/audio on the other. I try to have only one cross point between them when they do have to cross.
    -Lou
  • stonepimp
    stonepimp Posts: 34
    edited March 2006
    samsung makes a 6ft. length woven pvc cable tube that wraps around your cables and seals with velcro. costs about 4.00 cnd. and doesnt look bad either.
    Sharp LC-46D82U
    Yamaha HTR-6190b AVR
    Pioneer DV-578A
    Sony PS3
    Sony CDP-CE375
    Sharp VC-H953
    Belkin PureAV Home Theatre Power Console PF60
    polkaudio R30-Mains
    polkaudio R30-Rears
    polkaudio Csi3-Center
    Paradigm PS 1200
    Harmony 880 Universal Remote Control
