Yes or No
tonyb
tonyb Posts: 33,072
edited March 2006 in Electronics
I could be wrong,but some one settle this arguement i am having with a friend.When you connect a CD player or even a DVD player by the digital connection to a avr or processor,you are useing the DAC in the processor or AVR.True or not?You turn your cd player into an expensive transport.Iknow this has been discussed.Of coarse there are exceptions....but generally speaking,YES OR NO....Deal..or no Deal. {love that show}
Post edited by tonyb on
  • amulford
    amulford Posts: 5,020
    edited February 2006
    your using the receiver's DAC. Kinda maybe. Which one has better DAC's? which one sounds better?
  • michael_w
    michael_w Posts: 2,813
    Yeah when you hook it up like that you're using the avr's dac. If you use analog connections then it lets the dac in the player do it's thing.
  • ND13
    ND13 Posts: 7,601
    Ci..
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
    heiney9 Posts: 25,445
    Yes, but you have to determine which sounds better to you. It's a strech to say if you do it this way your turning your cdp into an expensive transport. It's still the same transport no matter how you decide to hook it up.
    YES.
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    THIS IS IT. When you use a digital connection (optical-coaxial) you're using the Avr's DAC. If you use the analog (composite) connections, you're using the Cd-Dvd's DAC.
    Anyway..try to uses digital !!!! :D
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
    tonyb Posts: 33,072
    Thanks guys,you just won me 20 bucks.It was a theoretic question ,I do not have that problem,just a point of contention between me and a pal.Thanks for you response....and NOOOO not shareing the 20.00
  • cmy330go
    cmy330go Posts: 2,341
    ....If you use the analog (composite) connections, you're using the Cd-Dvd's DAC.
    "Composite" is a video connection.
    Just a FYI.:)
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • ND13
    ND13 Posts: 7,601
    I thought component was video and composite was analog:confused:
  • *Seby*-Polk-
    Just a FYI.:)
    You're right !!! . Thanks for the correction cmy .... :p
  • cmy330go
    Both are video, and both are analog. Composite is a single RCA style connector (usually yellow). Component is 3 RCA style (sometimes BNC) connections and are Red, Green, Blue.
    Digital video is either DVI or HDMI.
    HT
    2 CH
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2006
    Due to tests I've done with a 4 year old $129 panasonic dvd (weighs about a pound wet), I can say with some confidence that sonic differences in DAC's are far greater than differences in transports, speaking in relative terms.
    edited March 2006
    steveinaz wrote:
    Due to tests I've done with a 4 year old $129 panasonic dvd (weighs about a pound wet), and can say with some confidence that sonic differences in DAC's are far greater than differences in transports, speaking in relative terms.
    I'd have to agree.
    I opened up a Pioneer DVD player from about 4 years ago and was completely disappointed with what I found (or didn't find) inside. Nothing more than a drive and a small pc board. The PS was so small it was laughable. If I didn't have an outboard DAC, I would listen to any DVD's at all.
  • steveinaz
    edited March 2006
    I ran my Panny for a week into my DAC as a CD transport, the differences from my $600 C.E.C. were so subtle I would suspect that it was the lower grade Toslink connection that the Panny uses for slightly better performance of the C.E.C. I would bet that if the Panny had a coax dig out, I probably wouldn't have heard any difference between the two...that's how close it was.
  • noimposse
    noimposse Posts: 264
    edited March 2006
    I think Ill chime in here with my own question....
    So if you are using digital, thus not using the dac in the dvd player, what differentiates the 100 dollar sony dvd play from a 2000 Denon dvd player?
    I'm assuming video correct? If not please correct me, I would like to know.
    Ghetto Rig
    Power: HK AVR245.
    Screen: LG 24" 1080p.
    Speaks: Rti4.
    Source: PC. PS3. Xbox360.
    Cables: BlueJeans. Monoprice.
    tonyb Posts: 33,072
    edited March 2006
    AAAHHHHH.....I see I started something here.
  • steveinaz
    edited March 2006
    Yes, video quality, upgraded power supply, better build-hence better transport isolation, etc, etc...
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2006
    VIDEO!
  • noimposse
    edited March 2006
    Alright, I was just making sure. So theoretically, if I have a sub-par Sony player with coax out, but only a small Sony Trinitron CRT, there really isnt a point in me spending 500+ on a dvd player so long as I have a good reciever and speaker setup?
    Ghetto Rig
    Power: HK AVR245.
    Speaks: Rti4.
    tonyb Posts: 33,072
    edited March 2006
    There are alot of variables in this,if you want better video yeah,can your tv support that better video,hmmmm....IMHO,the difference in a 200.00 player and a 500.00 player is mediocre at best.Want sacd then upgrade the player.
    Want better audio and video,you must also get a display that will keep up.And a machine with a decent dac for audio.Again IMHO,save your dough and make it count when you move up.Just my 2cw.
