Wiring Rear Speakers Help
smalltownheel
smalltownheel Posts: 39
I'm trying to figure out how to run wire for two rear speakers to be mounted on the rear wall. My house is old, and there is a wall joist that runs horizontally in the wall, making this a little tricky. A custom installer told me he uses a flexible drill bit to go through the joist, but the bit is not accurate at all, and a lot of the time, he has to do some patch work. Any ideas?
Post edited by smalltownheel on
  • Pablo
    Pablo Posts: 723
    edited February 2006
    If you have tall ceilings you can run it under some cown molding. You can also try running it under the baseboard molding. This is also some flat speaker wire out there that is paintable that will hide well.
    If you don't want to do any patch work (and in an old house, it will probably be a lot of patch work), there really won't be a real good way to totaly hide the wires.
    Good luck.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • peteran
    peteran Posts: 141
    If you have a carpet use flat speaker wire. I also live in a old house and running wires through walls was not an option so I got 12 gauge flat speaker wire for my rear channels.
  • WilliamM2
    WilliamM2 Posts: 4,807
    Is there an attic? If so, you could run them that way, assuming the joist is below where you want to hang the speakers.
  • smalltownheel
    yeah i thought about running it through the attic, it just makes for such a longer run. might have to go that route though
