Speaker Level Questions
jesyjames
jesyjames Posts: 52
edited August 2002 in Speakers
Not sure if anyone knows the answer to this, but the long and short of it is that when I use the AVIA Home Theater Calibration DVD to set my speaker levels that there is a quite a vast difference between the db levels using the receiver's(sony) built in tone tester.
I spent about 20 minutes getting it perfectly calibrated according to the AVIA DVD, all the speaker levels identical. And I'm happy with myself. Then, I get the bright idea to test out the receiver's built in tone tester and find my center channel is too high by 3 db and my rears are 5 db too high.
Which one should I calibrate it according to?
I'm thinking the AVIA DVD because maybe there is a level change associated with the DVD player's connection to the receiver that isn't accounted for just using the receiver's own test tones.
Any ideas? or help?
-eric
Post edited by jesyjames on
  • trubluluc
    trubluluc Posts: 2,067
    edited August 2002
    My regards to your brother Frank.
    Personally I would go with the avia disc, because it is just that, a disc, moving the sound from your DVD player.
    But....after calibration...do just that, pop in a movie and give a listen.
    Compare it to calibrating it to the Sony test tone, and see which you like better.
    I personally like having the center up a bit,
    to get the dialog out.
    -Luc
  • JediCowboy
    JediCowboy Posts: 56
    edited August 2002
    I, too, found a bit of a difference between setting my levels from the Denon internal calibrations (tuned to 75dB) and the Avia DVD (85dB). At first I was using the 75bB levels provided by the Denon, but after a little experimentation I've come to prefer the levels from the Avia DVD.
    My complete system settings can be found here:
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=164462
    The surrounds are a bit high, but I think that's due to the dipole surrounds and the L-shaped room.
    The Force is with Me -- YEEHAW!!!
    Denon 3802
    Mains -- RTi70s Biwired
    Center -- CSi40 Biwired
    Surrounds -- FXi50s
