Vintage receiver clean up help
gacole2000
gacole2000 Posts: 255
edited February 2006 in Electronics
Hello,
I have a vintage Pioneer and Yamaha receiver that I think need a good cleaning. The both still work excellent, except that whenever you turn up the volume it is REALLY scratchy and the channels kind of fade in and out until you find a "sweet" spot, then all is well. I think I read somewhere that this is caused by dirty contacts? If this is true, can someone point me to a good article on exactly how to solve this problem. I am fairly handy and feel confident I can do it with the proper guidance. Please advise. Thanks!
Regards- Greg
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
Post edited by gacole2000 on
  • dorokusai
    dorokusai Posts: 25,576
  • jimi64
    jimi64 Posts: 85
    If your comfortable with getting into them with a soildering iron,hit all the solder points with a hot iron.They are known to deteriate which can result in what you are experienceing.Happy soldering!!!
  • dorokusai
    Solder connections fail due to movement or improper soldering in the first place(e.g. cold joint). They just don't "decide" to fail.
  • jimi64
    jimi64 Posts: 85
    Didnt say they (decided to fail).They do fail from time to time for whatever reason and a person can go in there with an iron and clean up any bad connections.All said and done for the few cents it costs to run the soldering iron.Without there being any failure due to parts,this will fix the problem 99 percent of the time-without buying an overprived fix-it-from a sales rep
  • dragon1952
    dragon1952 Posts: 4,919
    Like doro said...easy fix. Pop the cover and hit the pots with some electrical contact cleaner. Works like a charm.
  • gacole2000
    Thanks for your replies. I went to Rat Shack after finding a good thread online. Bought a $9 can of contact cleaner, hit both volume knobs and they are both working like a champ. Sweet!!
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • dorokusai
    They fail via fatigue and usage, not by existence.
    The touch-up idea, via soldering iron, is solid. I've worked out more than a few issues via soldering iron work.
  • TroyD
    TroyD Posts: 13,124
    The contact cleaner at RS is crap.
    Caig products is where it's at.
    BDT
  • jcaut
    jcaut Posts: 1,849
    BDT
    Glad you got it working, but I'll second the above comment. In the future I would recommend against using the contact cleaner from RS on anything that you actually care about.
    Jason
