HK 335 and sub
Willow
with my new HK335 is there a way I can use the xoverin the HK to pass all the LFE through to my rears and use the speaker cable line in?
I'm trying to clean up the front . The sub kinda throws it off. Also trying to make the HT (fronts, tv and gear) not be a massive focal point.
If it is possible and you have either tried it or currently have it this way how did/does it sound ?
Post edited by Willow on
Willow wrote:with my new HK335 is there a way I can use the xoverin the HK to pass all the LFE through to my rears and use the speaker cable line in?
You shouldn't notice where the bass is coming from...When I had my little 8" Velodyne, I knew where the bass was coming from...not good
now that I have the SVS, eveything blends real nice...the way it shouldPioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub -
In speaker setup you might try LFE = Sub + Surrounds instead of L&R. It has that option on my 235. Don't know if that will clean up your soundstage though.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
bass management is the fly in the hometheater ointment.
i don't think anyone has a true, universal solution.
THX certainly doesn't. They may think they do, but they don't.
Trust your ears, not a "Standard".
and yes, Ron is right-on about the 235, and it pertains to the 335 as well. -
on another topic regarding the HK, what can be done with zone 2 if I'm not using it ?
