HK 335 and sub
Willow
Willow Posts: 11,257
edited February 2006 in Electronics
with my new HK335 is there a way I can use the xoverin the HK to pass all the LFE through to my rears and use the speaker cable line in?
I'm trying to clean up the front . The sub kinda throws it off. Also trying to make the HT (fronts, tv and gear) not be a massive focal point.
If it is possible and you have either tried it or currently have it this way how did/does it sound ?
Post edited by Willow on
  • krabby5
    krabby5 Posts: 923
    You shouldn't notice where the bass is coming from...When I had my little 8" Velodyne, I knew where the bass was coming from...not good
    now that I have the SVS, eveything blends real nice...the way it should
    Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
  • Ron Temple
    Ron Temple Posts: 3,212
    In speaker setup you might try LFE = Sub + Surrounds instead of L&R. It has that option on my 235. Don't know if that will clean up your soundstage though.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • aaharvel
    aaharvel Posts: 4,489
    bass management is the fly in the hometheater ointment.
    i don't think anyone has a true, universal solution.
    THX certainly doesn't. They may think they do, but they don't. :(
    Trust your ears, not a "Standard".
    and yes, Ron is right-on about the 235, and it pertains to the 335 as well.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Willow
    on another topic regarding the HK, what can be done with zone 2 if I'm not using it ?
