Storage Rentals ???
Burnzy
Burnzy Posts: 250
edited April 2024 in Clubhouse Archives
Has anyone ever used or are using one? How are they? I may be in need of one soon and was just wondering how they are. Yeeeeeears ago I used to hear (nothing official, just always rumor type stuff) horror stories of them being broken into but I'm sure that's old news.
Thanks,
Scott
SYSTEM
HDTV ..........Sony KP-57WV600
CD / DVD......Sony DVP-C675D
AVR ............Denon 2801
MAINS .........Polk RTi8
CENTER .......Polk CSi5
Surrounds ....Polk FXi3
Sub ............Polk PSW-250
Cables.........Zebra Cables
  • brettw22
    brettw22 Posts: 7,623
    edited February 2006
    I had one when I was in Phoenix....
    Check the difference in heights of the unit on the ground floor vs. upper. I got a ground floor unit that was 10' tall instead of the 8' in the upper levels. They price according to W & D, not H.
    I had a unit that had a gated entrance and was on camera. I also made sure that my unit was as close to the office as possible (more camera focus, people always there, etc).
    Good luck.
  • bobman1235
    bobman1235 Posts: 10,822
    I have one in a pretty crappy area and have had no problems. That being said I wouldn't put anything immensely valuable in one.
  • Willow
    Willow Posts: 11,217
    I too had one in a an ok area of town. It was temp controled but not humidity. So if you will be storing certain items which require humidity control, make sure you look for that.
    Mine was nothing but a 4x8 plywood casing about 10ft tall I never had a problem and I did not end up either with bugs.
  • Pablo
    Pablo Posts: 723
    My family had a few for a while and had no problems (3 of us were moving in & out of houses at the same time). This one was actually in a pretty crappy part of town, but the place was very nice. Most of the new storage places (chain ones) put a lot into security. This had a high gate with card access, cameras everywhere, 24hr on-site security (be it only an over weight guy with a blue shirt) and indoor climate controled storage (if you needed it).
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • Burnzy
    Burnzy Posts: 250
    Thanks for the replies guys...
    If I end up do needing one, I won't be putting anything of great value in it.
    Regards,
    Scott
    SYSTEM
  • bpadget
    bpadget Posts: 65
    I wouldn't store anything that I wouldn't be comfortable storing in a garage or outside shed at home. I also recommend storing things off the floor, on 4x4's or pallets.
  • nadams
    nadams Posts: 5,877
    ALWAYS put your stuff on pallets in a storage unit. We had one for a few months, over the winter, last year while we were building our new house and living temporarily in a smaller place. When we came back in the spring to empty it out, the floors would get puddles of water on the floor when you had the door open. The concrete just does that!
    Make sure the location has a good entry method (locking gate, keyless entry, that type of thing) and make sure the unit itself has a good lock on it.
    Ludicrous gibs!
  • schwarcw
    schwarcw Posts: 7,358
    I was thinking of living in one when I was between wives and paying alimony! $80/month with electric for a good size room.
    Carl
