That mystery cable
  • hoosier21
    hoosier21 Posts: 4,418
    edited February 2006
    dorokusai wrote:
    Big deal it won't fit? It might be a big deal if it doesn't fit what you own, and you bought it under the assumption that it would eh? The Ebay advertisement doesn't specify a model and is at the very least, misleading. The associated model(s) are ancient and if they haven't made it to the graveyard or dump, it's borderline amazing.
    The linked historical thread and pictures were all but forgotten until now.
    I agree, it won't fit 99% of the SDA speakers out there,
    Polk65 wrote:
    I started this thread hoping to learn if this was a genuine cable and it appears that it was used prior to the blade/blade cable.
    Thats how I read it from the beginng, my comments on this thread have nothing to do with that auction or how MANY speakers this type of cable will fit.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 51,805
    Validate what Russ? That you keep attacking anything I say? That you act like a spoiled little child? I don't have to validate any of that, you do a fine job all by yourself.
  • ohskigod
    ohskigod Posts: 6,505
    I guess the next mixed martial arts match is set for polkfest :D
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • dorokusai
    dorokusai Posts: 25,576
    Crouching Coif, Hidden Vomit
  • BobMcG
    BobMcG Posts: 1,585
    Thanks Steve for the great info and photos on a missing SDA link. Never knew about it to be sure.
  • steveinaz
    steveinaz Posts: 19,545
    ROTFLMAO!!!!!!!
  • Polk65
    Polk65 Posts: 1,405
    edited March 2006
    Polk65 wrote:
    Who can spot what else is different with the later version?
    Here is the difference I am curious about. Was there a pair of ports underneath the tweeters in the earlier model?
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2006
    The SDA 1 manual says the four midrange drivers operate as a "fourth-order vented system".
    A fourth-order (vented) enclosure is a sealed enclosure with the additon of a port tuned to a specific frequency. The purpose of the two small ports is to extend the low frequency response of the sealed enclosure in order to provide a lower cut-off frequency. The trade-off is that some transient response is sacrificed to achieve bass extension.
  • ESavinon
    ESavinon Posts: 3,067
    edited July 2006
    Isn't it great that we have raife and ken to sort these things out for us? I sure do think so!
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • DarqueKnight
    edited July 2006
    It's even better when you can catch a word or two from Matthew Polk. Here is what he had to say:
    "In the original SDA-1's there were 4 drivers. Two of these were dedicated to producing bass and driving the passive radiator. The other two drivers, one for producing the stereo signal and one for producing the SDA Dimensional signal, had their own enclosures which isolated them from each other and from the bass drivers. The small vents did help blending to the bass drivers but did not really "tune" the mid-band drivers. They were really more of a pressure vent to prevent buckling of the mid-range driver cones when driven hard.
    -msp"
  • Toka78
    Toka78 Posts: 192
    edited August 2006
    Missed this thread the first time 'round somehow, but wanted to add that my SDA 2's have the same 'mystery' interconnect (as well as dual SL-1000's). I bought them from the original owner, who was 'pretty sure' he bought them 'in 1984 I think'. Take that for what you will, but it does look like they made it onto more than one line.
  • Gary Batson
    Gary Batson Posts: 124
    edited July 2007
    My SDA1's have the same interconnect cable in question. It's a pin pin connector with a plastic socket that locks in place when its plugged in. Mine appears to me to be a better quality connector than ALL the other connectors. How's that for ego? :D
  • Boywonder
    Boywonder Posts: 225
    edited March 2008
    For future reference, if anyone stumbles across this post in need of one of these IC cables, the plugs and crimp contacts to build an IC cable for these early SDA-1's (or for the HF tweeter module for an RTA-12) are AMP parts and are available from Jameco.
    The connector is called an AMP snap-lock circular plastic (CPC) connector, also known as an AMP econoseal connector. The plugs are $6.49/ea at Jameco Electronics. You also need to order crimp socket contacts, and have a crimp tool for these connectors. The crimp contacts can be ordered individually. They should be quite inexpensive, even gold plated (if that's an option). Nickel plated contacts are 30 cents each and gold plated contacts are 99 cents each.
    The Jameco P/N is 839017 and the AMP P/N is 207567
    According to Jameco, compatible contacts are 66100-6; 66101-1; 66580-2; 66590-1; 51565-2 These various P/N's probably represent different plating, wire gauge, and whether they are for manual crimping or machine crimping.
    The max wire insulation size for these connectors is .100" according to the drawings, but if you pop out the rubber sealing booties, much larger wire insulation will fit.
  • Face
    Face Posts: 14,340
    edited March 2008
    Bad link Boywonder.
  • Boywonder
    edited March 2008
    Sorry about the bad link...I just modified the post to include the Jameco and AMP P/N's instead.
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2008
    Didn't read all replies, but I did see Boywonder's:
    Yes, that is a military connector. Amphenol makes them(expect to pay $ 10 a piece for the 3 pin).
    There are different diameters of connector available. That seems to be the larger diameter(maybe 1 inch) with only 3 pins. The 3 pins we used to sell were smaller(maybe 5/8" inch).
  • peppoman
    peppoman Posts: 2
    edited April 2008
    Does anyone have the schematic (or PDF) for the cross connection inside the cabinet ?
    I can make a cable with the right gauge wire, but my knucklehead brother pulled off
    the terminations for the +, - and G_ on each speaker.
  • peppoman
    peppoman Posts: 2
    edited April 2008
    Oops, the question about the crossconnect above is to SDA-1's
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2008
    Welcome to the Club Polk Forums pepoman!
    Look Here
    Carl
