Any opinions on Harmon Kardon T55C turntable
billbillw
billbillw Posts: 7,564
edited February 2006 in 2 Channel Audio
This turntable is the one that I've been thinking about buying locally. Any opinions on it and what is worth knowing it will need a new cart and belt?
From what I can tell, this is nearly the same as the T60C, but the 60 has a slightly heavier platter.
I know there are a lot of TTs out there, but for some reason I like this one. Its local for one, and I like the floating suspension design and the optical sensor for auto lift at the end.
Post edited by billbillw on
    F1nut Posts: 51,787
    Talk to BDT first.
  • TroyD
    TroyD Posts: 13,124
    Bill,
    I have a Technics DD turntable QD-1 or somesuch....FANTASTIC shape. The only thing it lacks is a headshell (about 10 bucks to replace). I have an Ortofon OM-10 cart with lots of life left in it that should work nicely.
    If this interests you, I'll let you have it nearly free of charge. I'd only ask a small donation, 25 bucks or so to:
    The Githens Center for the Handicapped
    40 Cedar Street
    Mt. Holly, NJ 08060
    If interested....lemme know.
    BDT
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    Far better is Technics turntables...The world leader brand in those "machines".
    Forget harman...Got Technics :)
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • hoosier21
    hoosier21 Posts: 4,418
    I have a Harman Kardon T60, not a bad entry level. got it off Ebay a couple years back when I wanted to try LP's again. I don't listen to many records, so it does the job, but even with the small amount I use it, I want to upgrade.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
