Any opinions on Harmon Kardon T55C turntable
billbillw
This turntable is the one that I've been thinking about buying locally. Any opinions on it and what is worth knowing it will need a new cart and belt?
From what I can tell, this is nearly the same as the T60C, but the 60 has a slightly heavier platter.
I know there are a lot of TTs out there, but for some reason I like this one. Its local for one, and I like the floating suspension design and the optical sensor for auto lift at the end.
Post edited by billbillw on
Talk to BDT first.Political Correctness'.........defined
President of Club Polk -
Bill,
I have a Technics DD turntable QD-1 or somesuch....FANTASTIC shape. The only thing it lacks is a headshell (about 10 bucks to replace). I have an Ortofon OM-10 cart with lots of life left in it that should work nicely.
If this interests you, I'll let you have it nearly free of charge. I'd only ask a small donation, 25 bucks or so to:
The Githens Center for the Handicapped
40 Cedar Street
Mt. Holly, NJ 08060
If interested....lemme know.
Far better is Technics turntables...The world leader brand in those "machines".
Forget harman...Got Technics
My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
I have a Harman Kardon T60, not a bad entry level. got it off Ebay a couple years back when I wanted to try LP's again. I don't listen to many records, so it does the job, but even with the small amount I use it, I want to upgrade.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
