Wireless Internet/Non-wireless router
Sami wrote:I don't think any cell phone protocol goes close to 2.4GHz. All GSM's are below 2GHz (850/900/1800/1900) and 3G's go to 2200MHz at highest. CDMA, I think, is 1900MHz.
Cordless phones tend to be 900MHz, 1.8GHz or 2.4GHz, I believe. NOt CELL, but actual landline cordless phones.If you will it, dude, it is no dream. -
Yep, 2.4GHz cordless phones share the frequencies with B & G networks, 5.8GHz phones share them with A networks. Cell phones do not share.bobman1235 wrote:Cordless phones tend to be 900MHz, 1.8GHz or 2.4GHz, I believe. NOt CELL, but actual landline cordless phones. -
Sami wrote:Yep, 2.4GHz cordless phones share the frequencies with B & G networks, 5.8GHz phones share them with A networks. Cell phones do not share.
I understand that part, but my son's cell phone plays havoc with his wireless connection. He will either loose connection, or speeds will drop to near 0, but he will move the cell phone into another room, or just shut it off, and connection returns to full strength. So there is some type of interference. But it has to be near his computer....wanted to make that clear. -
There is something wrong with his cell phone. Have it services.avelanchefan wrote:I understand that part, but my son's cell phone plays havoc with his wireless connection. He will either loose connection, or speeds will drop to near 0, but he will move the cell phone into another room, or just shut it off, and connection returns to full strength. So there is some type of interference. But it has to be near his computer....wanted to make that clear. -
no cell phone, **** just cuts out, i reset the router today for the third time, hopefully everything will be working right
Cisco beotches!!!
Cisco is great but it's a little out of the d-link / linksys price range. It's like comparing yamaha to rotel.
Not quite sure what's wrong Cody... I'll ask the guys at work tomorrow and maybe they'll have a quick fix. -
thanks, if all else fails, im buying a linksys
Just wondering, have you secured the connection? Change the SSID and hide it, create a new passcode. It's a long shot but worth a try.exalted512 wrote:thanks, if all else fails, im buying a linksys -
Sorry Cody, I totally forgot about this and didn't ask them yesterday
did that...Sami wrote:Just wondering, have you secured the connection? Change the SSID and hide it, create a new passcode. It's a long shot but worth a try.
i think im probably just going to ebay a linksys
whats the difference b/t these 2?
1.
http://www.bestbuy.com/site/olspage.jsp?skuId=5250774&productCategoryId=pcmcat25300050001&type=product&cmp=++&id=1051384663529
2.
http://www.bestbuy.com/site/olspage.jsp?skuId=6304082&type=product&productCategoryId=pcmcat25300050001&id=1074787298555
Another option:
http://www.bestbuy.com/site/olspage.jsp?skuId=5506785&type=product&productCategoryId=pcmcat25300050001&id=1051826245067
theres also this one, i dont have vonage, dont plan on getting it, but it has $90 in rebates...
http://www.bestbuy.com/site/olspage.jsp?skuId=7172178&type=product&productCategoryId=pcmcat25300050001&id=1110267188736
Out of those, which would you get? We do have a high speed cable connection. Both of us use it for gaming, but the wireless part will just be used for regular internet usage, mostly for school.
guys just get a Linksys WRT54G and be worry free. there is no need for these 2 pages of discussion. the linksys is one of the best routers on the market today and with open source firmware its even better.
