Who has the biggest mess?
BullShifter
BullShifter Posts: 66
edited April 2024 in Clubhouse Archives
Post photo's of your wiring mess
Behind audio
Behind PC
Hopefully by next weekend I can post the "after" pic's of how it should look.
HK AVR 335
Polk R50 fronts
Polk CSi25 center
Polk R15 rear
2 Sony modded subs with 12" Daytons
32" Sharp Aquos
PS2
    VR3 Posts: 29,437
    edited February 2006
    Hmm...
    Its actually alot neater than the pictures make it look.
    The DVDP, VCR, XBox : Power and Patch Cables are all twisty tied together and routed together away from the amp, pre, cdp - same goes for the cable cable...
    The Amp, pre, CDP, SUB power cables are all routed together.
    The XLR and speaker wire cables share the same hole on the back of the TV stand, the patch cables from the CDP to the preamp are isolated from everything - in other words, everything in the main components are isolated from everything "grunt"
  • beardog03
    beardog03 Posts: 5,550
    I have so much in cables, that I like to keep em out where I can see em..!!!
    J/K
    I`ll get some pic`s later
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    VR3 Posts: 29,437
    Ive seen a guy... who put his equipment rack in the middle of his room so he could look at all his cables and show them off...
    I wish I had a picture of it...
  • danger boy
    danger boy Posts: 15,722
    Bull I clicked just below your picture.. where is says.. report this message if this is offensive.. so i did. :p
    bad man.
    Hey nearly everyone has some kind of snake pit behind at least one of their systems... i know i do.
    PolkFest 2012, who's going>?
  • bobman1235
    bobman1235 Posts: 10,822
    This was when I disconnected my old system (to clean everything up). I feel like this picture doesn't do the rat's nest justice, honestly.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Are you guys trying to kill dan?
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • steveinaz
    steveinaz Posts: 19,545
    One of the best 'tweaks' in the world for getting a silent background is cable dressing.
    Now get busy you pigs...
    heiney9 Posts: 25,441
    Hey guys, I'm assuming some of these photo's are from HT set-ups? No way in hell my 2-ch could have that many wires. Although I just looked behind my TV and it ain't pretty. Mostly because of all the long cable TV coax and long interconnect cables from DVDp and VCR. It makes it look much worse than it is. Cable management is key for ultra good sound, plus it just plain looks like you care ;) . So clean up those rats nests :D .
  • wingnut4772
    wingnut4772 Posts: 7,519
    I don't feel so bad now looking at those pics. :p
    I have kinda given up on having everything neat back there. I do the best I can and try to get well shielded stuff.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • steveinaz
    Never met a system yet that couldn't be dressed correctly--just takes a little planning and a **** load of cable ties/cable tie mounts (Radio Shack).
    Get digital/analog/AC/speaker away from each other bundle loosely when needed. Try to let them hang without bundling if you can (like AC cords hanging down a vertical rack). It's harder with horizontal racks, but can be done. All of my ac cords run straight down from the component, and then is tucked under the rack, routed to the panamax. AC is at least 8" away from my speaker cables. I order my RCA cables to the proper length so there's not alot of loose cabling. My pre to amp is .5mtr; DAC to pre .5mtr; CDP to DAC 2ft; everything else is 1mtr.
    Next, I'm gonna have Signal Cable make me some custom length AC cords, then, when I'm REALLY bored, I'm going to replace my Kimber 8TC 8ft set with a 6ft set.
  • Ricardo
    Ricardo Posts: 10,636
    I've tried to keep it "clean", but as components are added it gets more and more difficult....it does not look good right now...
    This "rack" has:
    HT:
    Receiver, DVD player and Tivo; Output to 7.1
    2 Channel:
    1 pre amp
    2 CD players (One single disc, one 5 discs)
    1 DAC (used for the CD changer)
    2 amps (one for SDA's, one for Atrium's in the backyard).
    1 power conditioner
    Lots of cables :)
    SOPA
  • Skynut
    Skynut Posts: 2,967
    I gota get a picture of mine in here.
    I used to feel bad but now I wana show off.
    Sort of.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Tour2ma
    Tour2ma Posts: 10,177
    My HT rig, front and back... the beauty of solid back cabinets is they hide a multitude of sins. Plus the gear is all in a room apart form the listening area.
    Now if I can just get my CD collection under control...
    More later,
    Tour...
    Vox Copuli
  • Demiurge
    Demiurge Posts: 10,874
    Micah would say P. North. ;)
  • madmax
    madmax Posts: 12,434
    I'm kinda put to shame here. My system looks worse than any of these, and that is on the front side. As for the back, I've lost whole sets of interconnects, tubes, a DVM and a table lamp that I have never found back there. :eek:
    madmax
    Vinyl, the final frontier...
  • danger boy
    i try and keep all my cable runs as short as possible.. except the speaker wires... so i can move them around later if needed. but IC's, video cables, etc... i only buy them in the length that i need.. nothing extra to clutter it up.
  • gshisme
    gshisme Posts: 1,038
    madmax
    Great Stuff!
    suds, suds and more suds!
  • audiobliss
    audiobliss Posts: 12,518
    madmax
    I gotta say, that's about the third thing I've read on this forum that's made me laugh out loud. You gotta post a pic!
    LOL
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
