What makes an Amp dead quiet ?
beardog03
beardog03 Posts: 5,550
edited February 2006 in Electronics
Is it the Jensen oil caps ?
what can one do to an amp to make it dead , pitch black quiet..?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • Frank Z
    Frank Z Posts: 5,860
    Turn it off....
    Oh come on...you were all thinkin' the same thing. :D
  • beardog03
    wwwwwwwaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    okay, while it`s plugged in and turned on..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    I can hear crickets chirping...!
    I should have asked what is the sound you get when you ask this question..!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • pjdami
    pjdami Posts: 1,894
    How quiet is "quiet"? Like do you have to put your ear next to the tweeter to hear the noise or do you hear a noise from your chair?
    Very efficient speakers will tend to generate more noise if your amp is "noisy."
    Another problem is the cable / satellite system. Try unplugging your cable / satellite receivers from the outlets to see if that helps.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Circuit design, massaging negative feedback, design of and/or isolation of the power supply, discrete output stage, etc etc...
    Is your Cary black?
  • beardog03
    Let me explain a little..
    My new Cary makes no sound what so ever , no matter how high I turnthe knob up while no music is playing..
    same electrical plugs, same I/C`s, same speaks, wires etc.
    My Parasound 3500..turn it up with no music playing and I get a faint hiss that will get louder as the volume is turned up..
    not too bad but it`s not dead quiet like the Cary..
    I want to make like the Cary...
    no sound when the music is not playing, and a pitch black background while it is....
    what can I do to achieve this..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    Is your Cary black?
    Green.. :D
    British Racing green.. :cool:
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dorokusai
    dorokusai Posts: 25,576
    Nothing.
  • beardog03
    bummer
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Ferres
    Ferres Posts: 310
    This is odd. :confused:
    I use a parasound 2200II. It also has that 'faint hiss' but it doesn't get hissier as you raise the volume. I have to get my ears right next to the tweeter in order to here the hiss. :)
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • RuSsMaN
    It's not a bummer, it's hifi broham.
    Black is real, and not just a badass track laid down by Pearl Jam.
  • Ferres
    Ferres Posts: 310
    Just a follow up. Tested the Parasound 1200II and yes this one has similar hiss issues with your 3500. You can even hear the volume nob through the speakers. :o
    Btw; according to this:
    http://www.stereophile.com/solidpoweramps/100parasound/
    There is a way to fix the hiss but it may require modding. :(
  • cfrizz
    cfrizz Posts: 13,415
    Unless you sit on top of your speakers whether or not you playing music it shouldn't be a problem, cause you have to be in order to hear the hiss!
    Look at it this way, if you hear the hiss, you know the amp is working!
    Sheesh!
  • beardog03
    cool read, but he didn`t say what they did to it...
    I don`t hear my volume knob, but I do hear a slight hiss...it`s not real loud, but it does exsist....
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    Sheesh!
    I know, but I`m tryin real hard to be an audiophile...... :D;)
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dorokusai
    You are an audiophile Robert, stop thinking so much.
    If this is your head now, good luck in your travels in the future because you'll never get to where you think you're going, ever.
  • beardog03
    I love my 3500..
    I`m going on a bike ride with thw wife to the coast today...
    If she keeps it up , I may just leave her there too...!!!
    The Cary has been on since I got home last night, and the Parasound has been on since I got up this morning..
    When I get back this evening they both should be just shy of the magic 100 hrs marker...
    I`m just getting started... :D
    and neither one is going anywhere, along with the cary pre...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • SuperDave
    SuperDave Posts: 168
    Its called signal to noise ratio measured in minus 115+DB or greater :eek:
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • bknauss
    bknauss Posts: 1,441
    Power supply problem most likely. Or, not really a problem, more of not a perfect design. If the noise changes with volume, its generally a noise in the signal path before the amp.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • ward91
    ward91 Posts: 338
    why dont you unplug all the input leads to see if the noise is internal or its going through a input cable.
    just a sugestion
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • madmax
    madmax Posts: 12,434
    Play a record. All your worries will go away about that little hiss. :)
    madmax
    Vinyl, the final frontier...
  • ward91
    ward91 Posts: 338
    good idea madmax
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
