What makes an Amp dead quiet ?
beardog03
Is it the Jensen oil caps ?
what can one do to an amp to make it dead , pitch black quiet..?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
Post edited by beardog03 on
Turn it off....
Oh come on...you were all thinkin' the same thing. -
wwwwwwwaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
okay, while it`s plugged in and turned on..!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I can hear crickets chirping...!
I should have asked what is the sound you get when you ask this question..!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
How quiet is "quiet"? Like do you have to put your ear next to the tweeter to hear the noise or do you hear a noise from your chair?
Very efficient speakers will tend to generate more noise if your amp is "noisy."
Another problem is the cable / satellite system. Try unplugging your cable / satellite receivers from the outlets to see if that helps. -
Circuit design, massaging negative feedback, design of and/or isolation of the power supply, discrete output stage, etc etc...
Is your Cary black?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Let me explain a little..
My new Cary makes no sound what so ever , no matter how high I turnthe knob up while no music is playing..
same electrical plugs, same I/C`s, same speaks, wires etc.
My Parasound 3500..turn it up with no music playing and I get a faint hiss that will get louder as the volume is turned up..
not too bad but it`s not dead quiet like the Cary..
I want to make like the Cary...
no sound when the music is not playing, and a pitch black background while it is....
what can I do to achieve this..?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
RuSsMaN wrote:Circuit design, massaging negative feedback, design of and/or isolation of the power supply, discrete output stage, etc etc...
Is your Cary black?
Green..
British Racing green.. :cool:Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Nothing.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
bummerCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
This is odd.
I use a parasound 2200II. It also has that 'faint hiss' but it doesn't get hissier as you raise the volume. I have to get my ears right next to the tweeter in order to here the hiss.Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
Conditioner: Isotek -
It's not a bummer, it's hifi broham.
Black is real, and not just a badass track laid down by Pearl Jam.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
beardog03 wrote:My Parasound 3500..turn it up with no music playing and I get a faint hiss that will get louder as the volume is turned up..
Just a follow up. Tested the Parasound 1200II and yes this one has similar hiss issues with your 3500. You can even hear the volume nob through the speakers.
Btw; according to this:
http://www.stereophile.com/solidpoweramps/100parasound/
There is a way to fix the hiss but it may require modding.Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Unless you sit on top of your speakers whether or not you playing music it shouldn't be a problem, cause you have to be in order to hear the hiss!
Look at it this way, if you hear the hiss, you know the amp is working!
Sheesh!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
cool read, but he didn`t say what they did to it...
I don`t hear my volume knob, but I do hear a slight hiss...it`s not real loud, but it does exsist....Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
cfrizz wrote:Unless you sit on top of your speakers whether or not you playing music it shouldn't be a problem, cause you have to be in order to hear the hiss!
Sheesh!
I know, but I`m tryin real hard to be an audiophile......Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
You are an audiophile Robert, stop thinking so much.
If this is your head now, good luck in your travels in the future because you'll never get to where you think you're going, ever.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I love my 3500..
I`m going on a bike ride with thw wife to the coast today...
If she keeps it up , I may just leave her there too...!!!
The Cary has been on since I got home last night, and the Parasound has been on since I got up this morning..
When I get back this evening they both should be just shy of the magic 100 hrs marker...
I`m just getting started...
and neither one is going anywhere, along with the cary pre...Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Its called signal to noise ratio measured in minus 115+DB or greater :eek:SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
Ferres wrote:This is odd.
Power supply problem most likely. Or, not really a problem, more of not a perfect design. If the noise changes with volume, its generally a noise in the signal path before the amp.Brian Knauss
ex-Electrical Engineer for Polk -
why dont you unplug all the input leads to see if the noise is internal or its going through a input cable.
just a sugestionELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
Play a record. All your worries will go away about that little hiss.
good idea madmaxELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
