A sub for a truck...
VR3
VR3 Posts: 29,443
edited February 2006 in Car Audio & Electronics
Im going to present a challenge to you folks...it might be hard, might not be...
Im in a regular cab truck, has the bench seat and all that...
Heres your challenge...
Find me a powered sub (or passive) that will fit behind my seat.
Here are the options I have found
1) Infinity Basslink
2) Bazooka Tube (which isnt really an option...more like a last resort, the earth is about to explode if you dont get a sub kind of last resort)
Now, i have personally heard/screwed around with the Basslink from Infinity for over a year (my Dad had one in his extended cab Nissan (A king cab - slightly smaller than todays King Cabs) - anyways... I was pretty impressed with it, wasnt that accurate - but it sure was better than the effing Rectal Tubes from Bapuka... - I KNOW I can pick one of them up for 250 shipped. The question is, is it too big... ?
Now assuming it is to big, or you guys can do me better...
Any other options out there?
Thanks for all the help! :)
Post edited by VR3 on
    VR3 Posts: 29,443
  • RoosterD
    RoosterD Posts: 36
    I built one. Find the box specs on a sub that doesn't need a lot of room, and build it yourself. I did it for $20 plus the cost of the speaker! It's really easy, especially if you have a helpful contact at a car stereo store for info like port length/size. I also had a standard cab truck. Dodge Dakota to be precise. You have to get an amp for it though. Good luck.
    Denon 3805S
    Denon 3910S
    Polk LSi 15's
    Polk LSi F/X's
    Polk LSi C
    Boston Pro 10" DIY Sub
    Samsung 5678W DLP 1080P
    PS3
    VR3 Posts: 29,443
    Do you have pics? Etc
  • neomagus00
    neomagus00 Posts: 3,899
    we all know you're perfectly capable of constructing something like this, and as for a small sub... pioneer makes a 4" deep 12" sub, or look at image dynamics subs - they require very little space...
  • RoosterD
    RoosterD Posts: 36
    Here check this out. http://www.ehow.com/how_4073_build-subwoofer-box.html
    Denon 3805S
    Denon 3910S
    Polk LSi 15's
    Polk LSi F/X's
    Polk LSi C
    PS3
    VR3 Posts: 29,443
    I know how to build a box, I was more so curious about your box. :)
    That Basslink is exactly the size it would have to be (7" deep to 3-4" deep (tapered in the front)...
    Yep, building a box is no big deal...
    Anyways...
    Neo --- Is Image Dynamics better than Pioneer...? Id like to stay away from Pioneer...
    And would the ID be better than the Infinity?
  • neomagus00
    put it this way - of those three choices, i'd get the ID sub and do my own box
    VR3 Posts: 29,443
    Do you have a link to it?
    And how big do you think itd have to be..power? etc
    Could you help me model a box?
  • MacLeod
    MacLeod Posts: 14,358
    Image Dynamics is one of the best audio companies on the market and their subs are up their with the W7!
    Now dude, as good as you are at building boxes and as critical a listener as you are, you should not settle for a Basslink. Buy you a good sub and amp, build a box and enjoy. Youll feel better about yourself, and even better you can trump all the little punks at school by being the only dude with a system that YOU built. ;)
  • exalted512
    exalted512 Posts: 10,735
    Go with an IDQ or www.reaudio.com and get an RE 10 or 12. You can get em for like $50 and are extremely accurate subs. The brand is RE and their bottom series is called RE(to clear up any confusion.) So technically is the RE RE12. I have an RE10 around the house somewhere and its an extremely accurate sub. I built a small ported box for it a couple months ago and put it in the truck for a week and it was extremely loud and still kept its sq. Another option is JBL, their GT(or GTO, the cheaper one) is also extremely good and you can pick em up for really cheap.
    -Cody
    VR3 Posts: 29,443
    How much do you want for your RE10?
    And how small of a box does it need (smallest possible)...
  • beardog03
    beardog03 Posts: 5,550
    I have q-logic truck box`s behind my seat with two 10" polk subs..
    works for me...!
    I`ll take some pic` s tomorrow when I get a chance..
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • MacLeod
    Another option Sid is a Kicker L5 8" sub. Here. Ive heard quite a few of these and they sound very good. The thing that makes them worth consideration is that they only take a .33 box which is very small but they still can handle 300-400 watts with ease. Plus the square shape gives them more surface area as opposed to a round 8.
    VR3 Posts: 29,443
    Is that more spl or sq?
    Im looking at SQ first - would the ID be a better choice?
  • audiobliss
    audiobliss Posts: 12,518
    I think the ID would be more SQ oriented, though I believe the Kicker has some decent SQ.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • MacLeod
    The ID is a strict SQ sub. Their IDQ10 is also an excellent choice. While it requires a little bigger box, it is still well below a .5 ft3. It wont handle as much power as the Kicker either but not by much.
    The Kicker is designed for mainly SPL but they still sound very good and rival some SQ subs Ive heard.
  • audiobliss
    exalted512 wrote:
    The brand is RE and their bottom series is called RE(to clear up any confusion.) So technically is the RE RE12.\
    I just read on another forum that the brand is actually Resonant Engineering, and the line of subs is RE. Never seen their name before, so I thought I'd mention it.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • chrisrud15
    chrisrud15 Posts: 48
    RE makes a great sub as does ID. Both of them are not very popular due to the fact that are they are mostly online dealers. It's hard if not impossible to find them in stores. VRX3M: the sub that i have is not an IDQ sub; it's just an ID8 V.3 sub. The IDQ are a little better than the ID sub but for extra $$$. The new IDQ Max subs are supposed to be crazy. If you reconsider about the ID8 V.3 sub , i dont mind because I would want the absolute best as well(but cant afford a 400 dollar sub). I honestly think that the ID8 V.3 would be plenty for you though . I had two 12's in my old reg cab F150 and they sounded pretty well but not really enough air space for 12's. Like the other guys build your own box and put a sub in it and you will appreciate it alot more.
    Chris
    HT- CS1, Infinity 12 in. sub, Onkyo receiver, m20's, and m10's
    Car- Polk MOMO 6500 components, alpine 2 channel amp, Pioneer HU, Infinity Kappa Perfect 10 in. sub, Diamond Audio amp
    VR3 Posts: 29,443
    Hey Chris,
    As soon I get some pics, Money Order is on the way :)
    ID8 will be more than enough for what I want to use it for. $60 is a nice price too! ;)
  • exalted512
    they were wrong. Their name used to be Resonant Engineering, now theyre just RE
    :o
    -Cody
    VR3 Posts: 29,443
    If I ever run a speaker co - my name will be a symbol - beatch.
  • exalted512
    ok prince...
    -Cody
    VR3 Posts: 29,443
    thats...KING to you. Bow down punk. ;)
  • audiobliss
    err...now it's 'formerly known as KING'...:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • landry_p2000
    landry_p2000 Posts: 1,313
    I am in the same boat as you are Sid, and I am going to run a Kicker 10" solobaric sub in an enclosure, with a Kicker amp. You can check it out on www.circuitcity.com. That is the probably one of the best sounds you can get for a reg cab truck. I did a demo this weekend in store, and that thing bumped out loud bass right in the sound room, so I can just imagine how it would be in a truck cab!
    I replaced the 4"x6" in dash and rear speaker with Pioneers, and a new JVC mp3/wma head unit. When the funds get right, I wiill be getting the Kicker package from CC or Crutchfield. Just my 2 cents.
    Landry
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
