F150 Help
BOWLMAN
BOWLMAN Posts: 47
edited February 2006 in Car Audio & Electronics
Hello, I am new to this site and have many questions..
I have a Ford f150 extended cab 2004 with factory sound.
I would like to upgrade starting with speakers, any suggestions..
thanks in advance
Post edited by BOWLMAN on
  • brettw22
    brettw22 Posts: 7,623
    I'm fairly new to the whole car audio thing myself, but you need to be a bit more specific.
    Anyone here could suggest stuff, but that could be from a Wal-Mart system, to one that could be a custom install costing tens of thousands.
    Start with a budget, and what you're specifically wanting (CD only? DVD? Adding speakers? Stock quantity?, Sub? etc).
  • BOWLMAN
    BOWLMAN Posts: 47
    brettw22, thank you for the help.
    I am looking to upgrade speakers first.Front door,then rear door,amp,then sub. I am trying to use existing speaker locations with minimal cutting.On a budget for now.Under $700.00 for speakers..
    home audio
    Denon avr 3803
    Denon dvd 1200
    B&W 703 front speakers
  • exalted512
    exalted512 Posts: 10,734
    you could fit mm6500s in the front doors with an adapter plate, i believe you have 6.5s in the rear which you could replace with momo coaxials...do you want to add a sub?
    -Cody
  • BOWLMAN
    BOWLMAN Posts: 47
    exalted512
    Yes I will be adding a sub in the near future.
    I have 5x7 factory in the front,will check the rear.
  • audiobliss
    audiobliss Posts: 12,518
    Shoot, man...with $700 you can just about get a rockin' system.
    Get the MMC6500 for up front, MMC650 for the rear, a PolkMOMO MM2104 10" sub for the low notes, and an Eclipse CD2000 HU for control. There you have speakers, sub, and an awesome HU, not just speakers, for not much over your $700 figure ($790). You add an amp to that, and you have a wicked system for about $1000.
    If I were to build a system today, I would use the MMC6500 up front, an Eclipse for the HU (maybe even that one), and a MM2104 for the sub.
    I would personally not even use rear channels, because they mess with the imaging and soundstage and are only really useful if you carry passengers around. Instead, I would put that money toward an amp. That way, it'd be cheaper to amp everything (fewer speakers), and you'd have more money for the amp(s).
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • MacLeod
    MacLeod Posts: 14,358
    If youve got 5x7's in the front doors I would go with the MMC5250's for there. But if youre just wanting a plug and play system and dont want to have to cut holes for mounting the tweeters then get the coaxial MMC525.
  • audiobliss
    Since he gave us a budget of $700...just for speakers...I'm assuming he wants something fairly nice. Which would necessitate components.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    Yes but not everybody that wants nice speakers want to cut holes in their sail panels for component tweeters.
  • neomagus00
    neomagus00 Posts: 3,899
    sure they do! but really, the suggestions so far are excellent... do the SRs fit into his price range?
  • exalted512
    a lot of ford trucks have factory tweeter holes in the door
    -Cody
  • BOWLMAN
    BOWLMAN Posts: 47
    Thanks for all the help and keep it coming.
    The front doors on my f150 do have holes already cut for the tweeters.
    What about the sub? Will it fit under the seat?
    Has anyone listened to the mmc570 speakers?
  • exalted512
    probox makes one that fits under the seat
    -Cody
  • BOWLMAN
    BOWLMAN Posts: 47
    I just purchased Polk mmc5250 speakers for the front doors,( should have went with the mmc 6.5s). Do I need a amp to power the speakers? Am using factory head unit.
    If so, how much power do I need??
    I will buy a seperate amp for the sub,at a later time.
    Thanks for the help
  • BOWLMAN
    BOWLMAN Posts: 47
    Sorry for the mix up..The speakers are mmc5250 component ..
  • audiobliss
    Yeah, for components you should buy an amp. If no one has given you some recommendations whenever I check in again tomorrow, I'll surf the 'net some for ya and pick out a few. (It's late over here...)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • BOWLMAN
    BOWLMAN Posts: 47
    Thanks for the help.... audiobliss
  • 98thumpin
    98thumpin Posts: 649
    700 for speakers man your really going all out im just spending 300 on speakers and im buying polk db 570's for the front and db690 for the rear im getting rear speakers because i carry passengers alot. im alos getting a polk db212-2 for my sub, and a mtx audio thunder high performance ta5601 amp.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
