polyfill ?
pentavolvo
Just built a sealed box for my 2 12" momo's, 1.7 cubes totaly, do I need to do polyfill... currently there isnt any
Post edited by pentavolvo on
spec calls for just under 1.8, so you should be fine... some people prefer the sound of a slightly larger box, which you can achieve by adding some polyfill... it's mad cheap, might as well try it... buy it at michael's or some other craft store, it's like 6 bucks for a huge bag...It's not good, very fundamentally simply not good. - geolemon
sweet how much should i use... its actually 1.76 cubes to be exact lol
minimal to however much you like... i'd put in a very light packing of polyfill, see how that sounds, if you like it better, keep packing more in until it's 'full' (i.e. the stuff is popping out of the box if you're not holding it back) or until you stop hearing improvement... it's an iterative process...It's not good, very fundamentally simply not good. - geolemon
You dont need any. Polyfill is used to make the box seem bigger than it actually is. In your case, your box is actually a smidge bigger than the specs so you do not need polyfill.polkaudio sound quality competitor since 2005
Polyfill will help out in tuning. If you want, do what Neo said till you find the sweet spot for your system.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Yeah, but the Polk engineers went to an awful lot of trouble to figure out that sweet spot so you wouldnt have to which in this case is .88 sealed. If you build your box to .88 then you dont need polyfill.polkaudio sound quality competitor since 2005
however, the sweet spot that polk spec's the box for is in one type of car... every vehicle will sound different with that .88 box, so some tuning is certainly necessary... consider that a single box will sound different pointing in different directions...It's not good, very fundamentally simply not good. - geolemon
Tunig is never really done
Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
all too bloody true, that... freaking tuning, why can't it just enjoy who it is, and be at peace with itself, instead of constantly adjusting itself to someone else's wishes?...It's not good, very fundamentally simply not good. - geolemon
