hdmi imput on tv
schwerhaiv
schwerhaiv Posts: 72
I am just purchasing a JVC 56 inch HDTV. It has a HDMI input and I assume coax (being delivered later this week). Now, I recently purchased a HK AVR 335. It has the three different colored connectors, but no HDMI. In fact, as I believe, there are very few receivers that have HDMI switching. I assume that the HDTV Direct TV sat box will have audio outputs AND video. But, I also thought that HDMI carried both audio and video. Net net, how does this work for the best in HDTV and audio HT?
Post edited by schwerhaiv on
  • r.camacho1
    r.camacho1 Posts: 36
    edited January 2006
    Use the HDMI cable to hook up to the TV, then use a optical cable to hook up the sat box to the HK receiver.
  • Willow
    Willow Posts: 11,231
    edited February 2006
    Or return the HDMI cable and use component. The 335 has component input.
    Use either toslink or dig-coax for your sound.
  • Lowell_M
    Lowell_M Posts: 1,660
    Is there any difference in picture quality between using HDMI, DVI, or component inputs, or are they all just different ways to get the same signal (same picture quality) to the TV?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • danger boy
    danger boy Posts: 15,722
    tests have shown that there is no difference in video quality between the three types of connectors. the only difference is the HDMI and DVI are all digital cables, and component is analog. but picture quality is the same..
    PolkFest 2012, who's going>?
  • adam2434
    adam2434 Posts: 995
    With HD cable, I do not think I can tell a difference between HDMI and component on my projector.
    However, with my DVD player, using the upconversion through the HDMI is a significant improvement (less noise, smoother more film-like picture) over sending a 480i or p signal through component. The upconversion is only available through the HDMI, so I believe this improvement is from the upconversion, not inherently from HDMI.
    Bottom line - based on my experience, I would only experiment with HDMI if you have an upconverting DVD player.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
