integrated ampli with RTI12
alfdib
alfdib Posts: 12
edited January 2006 in 2 Channel Audio
I know guys you'll say it's not power enough but if you should choose between:
Denon PMA 1500
Marantz PM17
or Marantz PM7001
wich one would you choose to drive my RTI12?
Thjis is what my budget can affor on used market...
Post edited by alfdib on
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    The Denon or the Marantz PM7001, both at 70 wpc, should be able to drive the 12's to moderate listening levels. Personally, I'd go for the Marantz.
    "God grooves with tubes."
  • alfdib
    alfdib Posts: 12
    edited January 2006
    you think that PM17 at 60wpc could not do the job? it's really far more expensive and it should carry more detailed sound.. or not?
    you would prefer PM7001 anyhow?
  • marvda1
    marvda1 Posts: 4,951
    edited January 2006
    can you get a hold to a denon pma 2000ivr ? it has more than enough current to drive the speakers. 80 watts 8 ohm/160 watts 4 ohm.
    Puritan PSM156
