Grayghost... I have a Q
HBombToo
Very Nice site!
Can you tell me about this?
MyHD HDTV Decoder/Recorder PC Card
Research What... a VP among us? Damn!
HBomb
HBomb
***WAREMTAE***
Post edited by HBombToo on
HBomb,
What would you like to know about the MyHD MDP-100 card in 20 questions or less?Best Regards, Cliff -
Can I use it on a Sony 57" Widescreen digital ready? How would I integrate it?
I am very ignorant on this whole high def thing and appreciate your patience in advance.
HBomb***WAREMTAE*** -
Hi Hbomb,
You can connect the MyHD card to your Sony HDTV using the component (YPbPr) input on the TV. MyHD outputs either RGBHV or Component and needs a 15-pin VGA to RCA connector breakout cable.
Here is info on ways to connect a PC to HDTV.
http://www.digitalconnection.com/Support/cliffnotes_14.htm
BTW, The latest beta software for MyHD allows DVD playback with scaling to 1080i to match your HDTV.
Printed it off and Thanks. I'm sure I'll have more Q's regarding this matter and I'll be in touch.
Regards
HBomb***WAREMTAE***
