Speaker choice
kmitchel
kmitchel Posts: 6
edited January 2006 in Speakers
I have room roughly 15x20.
Looking at getting
RTi6 fronts
RTi4 or FXi3 rear
CSi3 center
PSW 303 or 404 sub
Denon AVR-2105
Any suggestions, thoughts, comments would be helpful.
Post edited by kmitchel on
  • kmitchel
    kmitchel Posts: 6
    edited January 2006
    ... :confused: room has vaulted ceiling if this may help in any suggestions.
    VR3 Posts: 29,425
    edited January 2006
    HT mostly?
    RTi4 Fronts, Rear, CSi3 Center - SVS PB10 ISD Subwoofer
    www.svsound.com
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2006
    Thats a good sized room, you might want to consider towers instead of bookshelf speakers for the mains. FX speakers will provide a more difused sound field and work well on the sides or as rear speakers too. The 303 and 404 are fine for entry level subs but you might want to look at other brands as well.
    Can't help you with the Denon, never heard it.
    BTW, Welcome to the forum Newbie!! :p
  • kmitchel
    kmitchel Posts: 6
    edited January 2006
    will be 50/50 HT/Music
  • gregure
    gregure Posts: 871
    edited January 2006
    Not sure what your budget is, but here's a suggestion:
    RTi 8 fronts- big room, bigger speakers
    Csi 5 Center-don't skimp on the center-too important
    FXi3's rear
    Martin Logan Grotto subwoofer-best small sub money can buy, with a huge output despite its size
    Outlaw Audio model 1070 receiver (a whole hell of a lot better than Denon, for not much more).
    approx $3500
    That's an awesome system for a decent price. You could get away with Rti 6 mains, but the 8's would require less volume to get the sound field going for music, whereas the 6's would need more power to fill the room.
    The Grotto is the best 10" sub available. At $1000 it isn't cheap, but you cannot find a more musical sub, nor one that is that small (high spousal acceptance factor!) and has that amount of heft. Do yourself a favor and audition it before you buy a sub. You won't regret it.
    The Outlaw receiver is a great piece, their gear is oft recommended on the forum and elsewhere, and the receiver just got a great review in Home Theater magazine. At 65 wpc it's not the most powerful amp in the world, but those watts are realistic, unlike the Denon's ratings. The 2105 isn't a terrible amp, but is not enough for the discerning music listener. At 50% music, you need to do much better.
    Honestly, for a bit higher budget, you could be really happy, and be reasonably free of upgraditis. Put some thought into this, man, it's something you'll spend a lot of time with.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • Holydoc
    Holydoc Posts: 1,048
    edited January 2006
    I have to agree with Gregure on his recommendations on speakers with one exception. If you have room for it, an SVS sub will make the whole system rock the house. Also as greture said, do NOT skimp on the center speaker. A clear,crisp dialogue in HT is very important for the full effect.
    As for music, the larger RTi8's as a two speaker system will sound much fuller than the RTi6's for such a large room. The RTi6's only have a tweeter and 6.5" speaker working as both the mids and lows. The RTi8's have dual 6.5" speakers to help with the lower bass (10hz lower) and you can load them up with more power. Of course if space is a premium, then the RTi6's may be the best you can do. Just play your music as a 2.1 system rather than a 2 speaker system.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    what greg said- plus if you upgrade the cs to the 5 model, do the same for the F/X's in light of the vaulted ceiling.
    considering the size of your room and you using a sub- i would think the 6's would be just fine.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • GATOR3000
    GATOR3000 Posts: 355
    edited January 2006
    Yes, very good advice from all the above threads. For your room size go with the Rti8’s fronts. My HT area is about the same as yours and the 8’s will do a lot better than the 6’s.
    I have tested my HT setup with Rti6’s as fronts and than Rti8's as fronts with different DVD movies and the Rti8’s came as winners on all of them. Did the same with my Csi3 and Csi5 and the Csi5 sounds a lot better in my room than the 3.
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
  • kmitchel
    kmitchel Posts: 6
    edited January 2006
    should I go with the FXi series in the back or stick with RTis all around??
    I was hoping to keep my speaker price under $2K
  • louhamilton
    louhamilton Posts: 209
    edited January 2006
    If you can swing buying them both, try them out for 30 days and see which one you like better. Return the one you don't like for a credit.
    -Lou
  • aaharvel
    edited January 2006
    nm..
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • mlhm5
    mlhm5 Posts: 217
    edited January 2006
    HT mostly?
    www.svsound.com
    You just missed your fronts and sub for <$400 on ebay
    Link
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    Does that include the subwoofer???
    If that's your budget, then take your time and don't rush to buy every speaker tomorrow. Do it right the first time. As others have indicated, get floorstanders and the larger center channel, and maybe wait a while on the rear speakers. If you're willing to buy used speakers over the 'net, you'll save a ton of money. Also don't skimp on the sub. For your room size, entry level subs should not be considered. Get the biggest, baddest Hsu or SVS sub you can afford.
    "God grooves with tubes."
  • kmitchel
    kmitchel Posts: 6
    edited January 2006
    Thanks for all the advice!
    So I should get
    RTi8
    CSi5
    RXi5
    and then save for a sub?
  • donedroolin
    donedroolin Posts: 225
    edited January 2006
    Hey Gregure, Whats up?
    I have the same speaker set up except for the sub. Been trying to decide between the B&k 507 series two, Denon 4806 or a Parasound. Can't find the BK around by me would have to travel alittle to hear it or buy it. Since you have the 507 can you tell me how you like it. does it have enough power to drive the Rti10's. Did you have a different receiver before and did you notice a change in sound. I am also thinking about trading up to Rti12's within the year. Will the BK be enough for those. Sorry about all the questions but I'm going CRAZY deciding what receiver to buy. When I saw your thred It was like COOL now can ask someone who knows. THANKS for your help with this.
    TV- 52 inch LCD SONY BRAVIA XBR6
    TV- 42 inch PLASMA HITACHI ULTRA VISION
    AMP- PARASOUND HALO A-51
    CONTROLLER- PARASOUND HALO C-2
    FRONT SPEAKERS- LSi15's and LSiC
    REAR SPEAKERS- LSi7's
    SUBWOOFER- VELODYNE DD15
    BLU RAY- LG SUPER BLU BH200
    BLU RAY- SONY BDPS350
    GAME SYSTEM- NINTENDO Wii
    MONSTER POWER CONDITIONER
    WIRES- AUDIO QUEST and MONSTER
  • aaharvel
    edited January 2006
    kmitchel do an a/b comparo between the 6's and the 8's- with and without a sub before you spend the extra money on the 8's. I think you'll be pleasantly surprised.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
