Buzzing coming from Velodyne CHT-12 amp
BjornB17
BjornB17 Posts: 752
edited January 2006 in Speakers
My CHT-12 has had a problem for a while where i will hear a buzzing noise coming from the amp whenever it's playing a sound thats around 50 or 60 hz and its really annoying. Happens at all but the quietest volume levels. I emailed Velodyne and they said i can mail them the amp so they can fix it, but I was wondering if I can fix it if it's just something loose.
Are there any special safety precautions to handling the amp? Are there capacitors that need to dissipate after unplugging?
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2006
    Just send it in, make them liable for it.
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    but that means I won't have a sub to listen to for a while :(:(
    and wow, you replied in like 20 seconds!
  • jtgranby
    jtgranby Posts: 887
    edited January 2006
    Could be the cables :D
    JT
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    JT
    lol .
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2006
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    RuSsMaN wrote:
    Why did you post the link to their website?
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    send in the amp.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • RuSsMaN
    edited January 2006
    Maybe that would be a good place to look for a solution to your problem.
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    aaharvel wrote:
    send in the amp.
    I'll send it in if it is anything more complicated than a loose screw. Is there anything wrong with me touching the amp though (even if it's unplugged)?
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    Hmm, i took the screws off of the perimeter of the amplifier, but i cant get the darned thinged off. It's like its stuck on there. Any tips?
  • RuSsMaN
    edited January 2006
    Flathead, carefully around the edge, pry it off. Smaller the better.
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    Before you posted that, i used my leg as leverage and pulled it right off with lots of force. I realized that its just a big black box so i decided to screw it back on tightly, and now the buzz is gone. Back to basics i guess :)
    However, imagine that the flathead screwdriver is a much better way to go
