audio hookups
jtoddaz
A guy at Radio Shack today told me that if I only had a 3.1 system (right/left/center/sub) and no rear satellites that I should not hook my components(cd player/dvd) up by optical or digital coax, and only use the analog cable until i get a 5.1 system. He said that the digital cables would try to send sound to the rears and I would not get complete sound. Does it matter what receiver i have (hk avr435 on its way) Any thoughts?
Jeremy
Jeremy
Post edited by jtoddaz on
use the digital and set your receiver surround spkr output to "OFF".
the guy works where again? :rolleyes: -
Hey, I consider myself a novice. I try to get info wherever I can. But I would have to say that I really appreciate all the info that I have gathered here.
Jeremy -
And I bet he said only Monster would work. :rolleyes:jtoddaz wrote:A guy at Radio Shack today told me that if I only had a 3.1 system (right/left/center/sub) and no rear satellites that I should not hook my components(cd player/dvd) up by optical or digital coax, and only use the analog cable until i get a 5.1 system. He said that the digital cables would try to send sound to the rears and I would not get complete sound. Does it matter what receiver i have (hk avr435 on its way) Any thoughts?
Jeremy -
He did show them to me. (only digital audio they carried) but he did say that he wouldn't put any of their rear surrounds in his house so I know he wasn't completely FOS.
speaking of monster other than being over priced is it pretty good stuff? or is it all bsTV ................Sony kdl52xbr4
Reciever ........Denon AVR 988
Amp -............Monster MPA 2250
Bluray............Sony PS3 (80gig)
Hddvd............xbox 360 Hddvd
Power centers.Monster 3600II & 2600II & 1600 x2
Voltage..........Monster AVS 2000
Fronts ...........polk Rti12s
Center ..........polk Csi5
Rears.............polk Fxi5s
Sub ..............Infinity PS12
cables............Monster / DIY
Video games...XBOX 360 / Wii -
i would say its 99% bsdvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung -
Can someone tell me what the proper cross over setting is? I have the RM6700 satelite system with a PSW 202 sub woofer and a Harmon Kardon AVR 130 receiver.
The satelite specifications say the -3db limits are 130hz, does this mean I have to set the cross over to 130 hz or higher?
