How much does this thing draw?
DJMosfet
DJMosfet Posts: 15
Hi, I have a Dual Model XS10 Subwoofer. 375 Watts Peak 4Ohms
My friend let me borrow his Jenson 300Watt AX3022L Amp.
In under 10 Minutes it starts getting warm. I play it at a little above talking volume. Enough to raddle the clothes in my closet. Is it the amp or the sub, Im really confused as to why its drawing so much. :confused:
Post edited by DJMosfet on
  • karpiel666
    karpiel666 Posts: 173
    edited January 2006
    how warm is warm? most amps have a auto shutdown if they get too hot, just make sure it has plenty of breathing room.
    dvd player: samsung DVD-HD850
    receiver: Denon avr5700
    center: polk cs400
    fronts: polk rt800i
    surrounds: Unknown Polk monitor? series.
    sub: svs pb12 isd/v
    tv: 46 inch samsung
    F1nut Posts: 51,766
    edited January 2006
    Is the Jensen rated to drive 4 ohm loads?
  • DJMosfet
    DJMosfet Posts: 15
    edited January 2006
    Yep 4-8. well it hets to 100.6 and up. My friend claims its to hot. He gets waay to contious when I borrow his stuff. Im running it Bridged
    F1nut Posts: 51,766
    edited January 2006
    Well, there's your problem. You can't run 4 ohm speakers off a bridged amp. The amp is seeing the load as 2 ohms and as a result will run hotter than hell. You could be buying your friend a new amp very soon.
  • TroyD
    TroyD Posts: 13,124
    edited January 2006
    Your friend is justified in his cautiousness....
    BDT
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2006
    I Don't Know Why!
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2006
    I had a jensen when I was like 18(12 years ago) I had 2 cv 12's hooked up to it wired in parallel, and ran the jensen bridged( that's 1 ohm a channel) it was rated for 4 ohms a channel. The little bogger never failed, never went in to protection, but you could heat you car with it in the winter. Doesn't mean all jensen's are going to do this though
  • DJMosfet
    DJMosfet Posts: 15
    edited January 2006
    hahaha lol! :p It thinks its 2 Ohms thats weird :eek:
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2006
    Not really.... just circuitry. What you have is a parallel-parallel situation.
    And speakers don't "draw"... amps push.
    More later,
    Tour...
    Vox Copuli
  • DJMosfet
    DJMosfet Posts: 15
    edited January 2006
    well, this sub is in efficiant.
    My friend had 2 12 in Ultra Cadence Cometition Subwoofers Dual voice coil. It ran for hours with out getting warm. :D
    F1nut Posts: 51,766
    edited January 2006
    It's not the sub or the amp, IT'S THE WAY YOU ARE RUNNING THEM!!!
  • HBombToo
    HBombToo Posts: 5,256
    edited January 2006
    but Jesse... 1 Ohm is less than 4 so it should be easier to drive. :confused:
    I'm getting another beer and putting on PBS KIDS already :D
    HBomb
    ***WAREMTAE***
  • disneyjoe7
    edited January 2006
    But 16 12" Subs in parallel are .5 Ohms so even easier to drive then 1 Ohm....
    Hmmm 16 Subs what a SQL that would make.........
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • DJMosfet
    DJMosfet Posts: 15
    edited January 2006
    Woah calm down man jeesh :eek: I know that. Sorry
    VR3 Posts: 29,427
    edited January 2006
    The difference between your friends and yours is one thing...
    He has more wiring options.
    He has dual voice coils, so he can wire them to a higher ohm load then when its bridged it would be brought back down to normal...
    No? This is the difference.
    F1nut Posts: 51,766
    edited January 2006
    Henry..... :D
  • SuperDave
    SuperDave Posts: 168
    edited January 2006
    As long as it is your friend, crank'em up!
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • dudeinaroom
    edited January 2006
    yes their is less impeadance, but it is actually harder to drive(more current getting fed back to the amp, less resistance to ground . 5ohms is almost like hooking the speaker wire together with out having a speaker in line)
  • disneyjoe7
    edited January 2006
    Ok, I know I was just Kidding with you / all :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Tour2ma
    edited January 2006
    ... but it is actually harder to drive(more current getting fed back to the amp, less resistance to ground . 5ohms is almost like hooking the speaker wire together with out having a speaker in line)
    :confused::confused::confused::confused:
    See what you started, Steve?
    More later,
    Tour...
    Vox Copuli
  • HiPerf360
    HiPerf360 Posts: 436
    edited January 2006
    Is this 100.6* f or c?
    if it is 100* f that that is a delta of only 30* or so... Completly acceptable.
  • DJMosfet
    DJMosfet Posts: 15
    edited January 2006
  • fil1985
    fil1985 Posts: 1
    edited January 2009
    Hallo! I have subwoofer XS10 and I need to know Thiele-Small parameters, also known as TS parameters. Can somebody help me?
