Op Amp Upgrade - Onix XCD 88...?
VR3
VR3 Posts: 29,399
edited January 2006 in Electronics
Can anyone tell me what Op Amp this thing uses - I heard there was an upgrade for it...
What does it take to do it...
How much?
And where can I find it?
Thanks!
Post edited by VR3 on
  • hoosier21
    hoosier21 Posts: 4,415
    edited January 2006
    don't be afraid to use google :rolleyes:
    first hit I got this
    http://www6.head-fi.org/forums/showthread.php?t=122187&highlight=xcd-88+mod
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • SKsolutions
    SKsolutions Posts: 1,820
    edited January 2006
    Cool mod. Looks like you can do it without being a surgeon with the iron.
    -Ignorance is strength -
  • 2+2
    2+2 Posts: 546
    edited January 2006
    Really easy...took me 5 minutes...just because I was being very careful...
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • dragon1952
    dragon1952 Posts: 4,907
    edited January 2006
    I've made 4 or 5 sets of these for people here on the forum. The normal upgrade is the opa627. You can find them on Ebay for between $2.50-$5.00 each. The Browndog adapters are available through Cimmaron Technologies for around $2.40 apiece but they have a minimum order of 5 or 6. Those pictures are a bit misleading. The actual adapters and opamps are so tiny it makes it very hard to solder. You need a magnifying glass, some decent silver content solder, a very fine point on your iron, above average skills and a very steady hand. You can buy them already assembled from Upscale Audio I believe for around $60 per module. You'll need two modules. You can make them yourself for around $12 per module. I think I have one module already assembled but ran out of parts for the second one. I used the adapter pictured. One opamp mounts on each side so you need two opamps per module.
  • SKsolutions
    edited January 2006
    Luck for me, I AM a surgeon. I don't think an 8-dip regardless of size would be a challenge, unless it was in the dark, on a rowboat, upsidedown. But, that is just cause I'm really really really cool. But, thanks for the links- I may use them.
    Sean
