Op Amp Upgrade - Onix XCD 88...?
VR3
Can anyone tell me what Op Amp this thing uses - I heard there was an upgrade for it...
What does it take to do it...
How much?
And where can I find it?
Thanks!
How much?
Thanks!
Post edited by VR3 on
don't be afraid to use google :rolleyes:
first hit I got this
http://www6.head-fi.org/forums/showthread.php?t=122187&highlight=xcd-88+modDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Cool mod. Looks like you can do it without being a surgeon with the iron.-Ignorance is strength -
Really easy...took me 5 minutes...just because I was being very careful...System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
SKsolutions wrote:Cool mod. Looks like you can do it without being a surgeon with the iron.
I've made 4 or 5 sets of these for people here on the forum. The normal upgrade is the opa627. You can find them on Ebay for between $2.50-$5.00 each. The Browndog adapters are available through Cimmaron Technologies for around $2.40 apiece but they have a minimum order of 5 or 6. Those pictures are a bit misleading. The actual adapters and opamps are so tiny it makes it very hard to solder. You need a magnifying glass, some decent silver content solder, a very fine point on your iron, above average skills and a very steady hand. You can buy them already assembled from Upscale Audio I believe for around $60 per module. You'll need two modules. You can make them yourself for around $12 per module. I think I have one module already assembled but ran out of parts for the second one. I used the adapter pictured. One opamp mounts on each side so you need two opamps per module.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Luck for me, I AM a surgeon. I don't think an 8-dip regardless of size would be a challenge, unless it was in the dark, on a rowboat, upsidedown. But, that is just cause I'm really really really cool. But, thanks for the links- I may use them.
Sean-Ignorance is strength -
