HDTV..need advice for off air antenna
Ricardo
Today I pulled the trigger for a TV with built in HD tuner. While most people seem to be getting the new LCD/DLP or Plasma, I love the image of my "standard" Hitachi 51". Have always wanted a bigger screen, and a built in tuner, and did not want to pay $3000...so I got this:
http://www.circuitcity.com/ssm/Hitachi-57-HDTV-57F710A-/sem/rpsm/oid/121175/catOid/-12870/rpem/ccd/productDetail.do
With 24 months no interest it turns out to be a pretty good deal.
Now I need to get an HD antenna. would like the convenience of indoor, but I'm sure reception will be a lot better with an external, so am willing to wire what needs to be wired.
Any advice? What do you have that works ok? What bad experiences have you had??
Thanks!!!!
Thanks!!!!
SOPA
SOPA
Post edited by Ricardo on
It depends on how far you are from the HD towers as to which antenna you need. If you havent yet visit TitanTv, signup your address and then you will be able to get a good idea on antennas along with whats on HD.
I use the Channel Master 4228 because its at least 50 miles to the nearest tower but it works great.polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Zenith Silver Sensor is good for <20 miles.Brian Knauss
ex-Electrical Engineer for Polk -
Silver Sensor is OK, but I never had the best of luck with it (towers only 15 miles away and the SS in the attic rafters). I use a CM 4221 on a 20 foot mast with rotor. All my digitals are UHF, and it works great.Onkyo TX-SR601S receiver
Denon DVM-1815 DVD player
Polk RT55 Fronts
Polk CS245i Center
Polk RT25 Rears
Polk PSW10 Sub -
yeah, my little zenith sizucks. it's cute, though.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Thanks for the input; those links are great. I also found this thread.
http://www.polkaudio.com/forums/showthread.php?t=23383&highlight=air+antenna
Will probably go with something from Winegard; I like that Squareshooter..._________________________________________________
SOPAThank God for different opinions. Imagine the world if we all wanted the same woman
