In-Wall Subwoofer Cable??????
Lowell_M
I am finishing off my basement and wiring outlets for 6.1 sound. What should I use for cable in the wall from the Receiver to the outlet? I have about a 25' run I will need to make. I have a 30' Monster Cable subwoofer interconnect. Should I use that to go to the outlet and then get a shorter subwoofer cable to go from the outlet to the sub? Is there a more appropriate cable for that long of a run in the wall to an outlet? RG6??
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
You would need to put an outlet at both ends of the cable, which means you would end up with 3 cables and 4 extra connectors.
I use a blank wall plate, drill a hole in the center, and add a rubber gromet for both speaker wires and sub cable. That way I avoid all the extra connections. -
Good idea. I need to measure, but think that I need around 25'. Should I try to avoid going over 30'? If it is over 30', what could I use for cables?HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Ultra Bi-Wire Speaker Cables -
I used RG6 in wall to F type wall plates for my sub. RCA to F-Type adapters allowed me to use a 3' and 6' foot length of composite video cable (RCA-RCA) to connect the sub/AVR to the wall jacks. The sub works great. A couple of forum members have heard it in action.
The adapters are around $2 each. Either way suggested so far will work for you.
EDIT: I'm no pro installer so I don't know the max cable length you can use for a sub. I wouldn't think 30 feet would hurt you.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Great. Thank you for the picture and the idea. I think that I can even get an RCA to F connector for the wallplate and aavoid the extra connection.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
