In-Wall Subwoofer Cable??????
Lowell_M
Lowell_M Posts: 1,660
I am finishing off my basement and wiring outlets for 6.1 sound. What should I use for cable in the wall from the Receiver to the outlet? I have about a 25' run I will need to make. I have a 30' Monster Cable subwoofer interconnect. Should I use that to go to the outlet and then get a shorter subwoofer cable to go from the outlet to the sub? Is there a more appropriate cable for that long of a run in the wall to an outlet? RG6?? :confused:
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited January 2006
    You would need to put an outlet at both ends of the cable, which means you would end up with 3 cables and 4 extra connectors.
    I use a blank wall plate, drill a hole in the center, and add a rubber gromet for both speaker wires and sub cable. That way I avoid all the extra connections.
  • Lowell_M
    edited January 2006
    Good idea. I need to measure, but think that I need around 25'. Should I try to avoid going over 30'? If it is over 30', what could I use for cables?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    SCompRacer Posts: 9,128
    edited January 2006
    I used RG6 in wall to F type wall plates for my sub. RCA to F-Type adapters allowed me to use a 3' and 6' foot length of composite video cable (RCA-RCA) to connect the sub/AVR to the wall jacks. The sub works great. A couple of forum members have heard it in action.
    The adapters are around $2 each. Either way suggested so far will work for you.
    EDIT: I'm no pro installer so I don't know the max cable length you can use for a sub. I wouldn't think 30 feet would hurt you.
  • Lowell_M
    edited January 2006
    Great. Thank you for the picture and the idea. I think that I can even get an RCA to F connector for the wallplate and aavoid the extra connection.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
