Need Help Wiring
swchma
swchma Posts: 49
Hey out there,
I recently purchased the following:
Denon 3805 Receiver
Denon 2910 DVD
Polk PSW-505
Polk RTI-8 (front speakers) and have CS New Ensembles for the back and CS Center Speaker.
Questions::::
1. Should I connect my front RTI's to the sub and then route to the receiver or connect the sub directly to the Receiver and the subs to the receiver?
2. Should I connect my DVD with the multi-cables (six) to the receiver or just the one cable?
I am confused so your help is appreciated.
Thanks and put Zep CD in to clear your mind.
SW
Post edited by swchma on
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited January 2006
    Sub directly to sub out on receiver and since the 2910 is a SACD/DVD-A player you will want to use the six cables - otherwise no high rez sound from those SACD CDs. You may also want to have an optical connection from the 2910 to the receiver.
    If you use select the external 5.1 inputs (the six cables) on the receiver you are using the DACs in the 2910, if you select the optical connection input from the 2910 you will use the DACs in the 3805. So select the external 5.1 inputs when listening to SACD/DVD-A CDs and use either the external 5.1 inputs or the optical connection when watching movies. Experiment with which way sounds the best.
  • swchma
    swchma Posts: 49
    edited January 2006
  • Willow
    Willow Posts: 11,255
    edited January 2006
    set mains to small along with all other speakers and have the xover set at 80hz
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    you have Rti8's. Try the 60hz. setting on the xover as well.
    My 4's only show a -3db. at 60hz- check the specs for your 8's.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Willow
    edited January 2006
    wouldn't 60 put more strain on the reciever?
  • aaharvel
    edited January 2006
    sure- but it's not like they're running full range. And it's a Denon 3series. Those things aren't gutless by any means. They'll still be set to 'SMALL'. I say take advantage of the extra low-end capability that your 8's have to offer. Just a suggestion.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Willow
    edited January 2006
    No, good suggestion, I might even do that. it's worth a try. I found going from a 90 xover to 80 makes it more full. Wonder what 60 will do
  • aaharvel
    edited January 2006
    25-62hz is that magic number magazines constantly refer to for 'bass'
    wouldn't want my sub playing over that.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Pablo
    Pablo Posts: 723
    edited January 2006
    I have the same reciever (3803) and player. I have the cables for CDs and optical for DVDs. The reciever is set for the correct audio inputs for each mode. They both sound great, so I don't know if there is much of a difference. (Also, make sure you read that 2910 manual, lots of rules on how things have to be hooked up for what you are playing).
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
