What happenned to all the Polk Subs with Power Port technolgy?
Taurus574
Taurus574 Posts: 52
edited January 2006 in Speakers
Did they do away with it or somthing. It seems that their current line is only front radiating woofers instead of their other line with Power Ports. Maybe it didn't sell well?
Yamaha HTR-5490, Polk RT1000I, cs4000i, CS175 and R10 .... and a soon to be SVS 20-39 PCI
Post edited by Taurus574 on
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    It's called, "marketing." Gotta keep doing something different for the finnicky broad-based consumer market.
    "God grooves with tubes."
    VR3 Posts: 29,445
    edited January 2006
    Anothe problem was it created port noise in subs...
    So they went to the large slot port - or a slort port + power port combo...
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    I thougth the power port was supposed to reduce port noise?
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    This brings up an interesting point I have wondered about for awhile. Can a little curved cone at the port make all THAT much difference? I always found it kinda gimmick-y too but... thats why I dont design loudspeakers too :)
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • StopherJJ1980
    edited January 2006
    And a second though, has anyone ever HEARD port-noise on anything but a really poorly designed speaker? Seems to me like you shouldnt hear it on any decent speaker you buy.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Yamaha HTR-5740 AVR
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    I heard port noise with Onix Reference 1 ($1500), SVS 25-31PC+ ($775) to name a few...
    And I thought those two were well designed and the price reflects some of that design.
  • StopherJJ1980
    edited January 2006
    touchee :) lol
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Yamaha HTR-5740 AVR
    VR3 Posts: 29,445
    edited January 2006
    While the power port reduces port noise, that is mostly from a speaker stand point.
    Obviously if it worked for subs, they'd be using it a bit more than in COMBINATION* with a slot...
    I always really just throught Polk used the power port so you can put their rear ported speakers right up on the wall. because with the PP it distributes the air evenly on all sides instead of straight out - so it will have the same bass response regardless of whats behind it...
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    I think you're right Sid... it's probably also useful for positioning.
  • organ
    organ Posts: 4,969
    edited January 2006
    The PP is not a gimmick and not for marketing.
    Don't forget, the Power Port also increases bass by 3db and like others said, you can place them closer to the wall/corner than other speakers because the first refelction point is the power port.
    Polk is not the only speaker company that do funky things to their ports to reduce port noise. A lot of companies have their own technology to combat port noise.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2006
    Yeah, its called acoustic suspension. :D
  • organ
    organ Posts: 4,969
    edited January 2006
    Yeah, that's one way lol.
    I'm not talking about sealed designs though.
  • Taurus574
    Taurus574 Posts: 52
    edited January 2006
    If the PP was such great technology then it should be in the newer models but it's not. :confused:
