rta 15t
fshan
30-250 w/channel
edit: 30-250 is per the manual. Perhaps someone who attended the TPG can recollect what they pumped into it. -
thx, hmmm.......... I don't know which would sound better cause I never heard either,...
the rta15t or the sda 1c. The 1c is 500watts? -
I like the 15tl's a lot (biggest non-SDA speaker they made back in the day)but that's only 'cause I can't fit SDA's in my enviroment. If I had a bigger room I'd go for some SRS 2's
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
so you heard the sda's too? peersool?
which do you like better?
I only heard a pair of SDA-SRS 2's and - if I had the room - I'd take the SDA's in a second.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
thx for your opinion. wish I could hear some.
Why are you fixated on how many watts they can handle?Political Correctness'.........defined
President of Club Polk -
uhhh..........can't say as to how I was "fixated". .................just didn't know.
