LSi25s
kmartin971
Which velodyne sub should use with this system for movies?
LSi25s
LSiC
LSiFX
Room size is 15X22X8
LSi25s
LSiC
LSiFX
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
Post edited by kmartin971 on
I am biased and your room size is almost identical to mine. Checkout DD-15 or DD-18.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
What is the normal price range of the DD-15?TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
It varies, $2200-$4000. Check audiogon.comI am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
How about the spl-1200r. :PGear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
Conditioner: Isotek
With the powered subs in the LSi25's, why do you need a separate sub?Political Correctness'.........defined
President of Club Polk -
Good point old man. I'd Ronco that ****.
If you do go Velo, Digital Drive, or go home. You can't mess with that DD stuff.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I like the DD series but they are pricey. But if you have all LSi's then you got at least a decent wad of cash for home audio anyways. So DD, but I also found the DLS-5000r to be an EXCELLENT value if you wanna save a grand or two. only goes to 23Hz though, in room response might hit 20 depending on the room.-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Polk FXi3's Surround
Cerwin Vega HTS10 Subwoofer
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR -
F1nut wrote:With the powered subs in the LSi25's, why do you need a separate sub?
Hi Jesse,
I think if Kyle planned on listening just to music then the 30 Hz -3 dB limit on the LSi25's would be fine.
However, he stated that he was interested in movies, and nowadays action movies have really challenging bass.
My home theater (15'x24'x10') is just a little bigger than Kyle's room, and I'm using a Velodyne DD-15 for LFE. It has a -3 dB limit of 15 Hz, the DD-18 can go down to 14 Hz.RuSsMaN wrote:If you do go Velo, Digital Drive, or go home. You can't mess with that DD stuff.
Russ, I'm not sure I follow your comment.
Is that a thumbs up or thumbs down?
Larry -
Why limit yourself to Velodyne? Lots of other equal or better options out there. Most are cheaper, too.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Early B:
What other options do you suggest?TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
Well, not early B but I am sure you would hear the following....kmartin971 wrote:Early B:
SVS (almost a cult following, great subs for the cash spent - typicallly HUGE though with med. to low WAF (but killer lows))
HSU - would work fine in your size room. Very nice subs. (get a couple if in doubt)
If size and looks are important there are more than a few small subs that sound good to choose from. Like with anything else, you pay for the size though - higher dollar / performance ratio, but they do look cool. - look at Sunfire, and some of the paradigms.
I have heard decent things about the new polk LSi Sub, but just from specs I would put it more for music than movies.
