LSi25s
edited January 2006 in Speakers
Which velodyne sub should use with this system for movies?
LSi25s
LSiC
LSiFX
Room size is 15X22X8
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Post edited by kmartin971 on
Welcome!
    edited January 2006
    I am biased and your room size is almost identical to mine. Checkout DD-15 or DD-18.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    edited January 2006
    What is the normal price range of the DD-15?
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
    edited January 2006
    It varies, $2200-$4000. Check audiogon.com
    edited January 2006
    How about the spl-1200r. :P
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
    edited January 2006
    With the powered subs in the LSi25's, why do you need a separate sub?
    edited January 2006
    Good point old man. I'd Ronco that ****.
    If you do go Velo, Digital Drive, or go home. You can't mess with that DD stuff.
    edited January 2006
    I like the DD series but they are pricey. But if you have all LSi's then you got at least a decent wad of cash for home audio anyways. So DD, but I also found the DLS-5000r to be an EXCELLENT value if you wanna save a grand or two. only goes to 23Hz though, in room response might hit 20 depending on the room.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
    edited January 2006
    Hi Jesse,
    I think if Kyle planned on listening just to music then the 30 Hz -3 dB limit on the LSi25's would be fine.
    However, he stated that he was interested in movies, and nowadays action movies have really challenging bass.
    My home theater (15'x24'x10') is just a little bigger than Kyle's room, and I'm using a Velodyne DD-15 for LFE. It has a -3 dB limit of 15 Hz, the DD-18 can go down to 14 Hz.
    Russ, I'm not sure I follow your comment. :confused: Is that a thumbs up or thumbs down? ;)
    Larry
    edited January 2006
    Why limit yourself to Velodyne? Lots of other equal or better options out there. Most are cheaper, too.
    "God grooves with tubes."
    edited January 2006
    Early B:
    What other options do you suggest?
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
    edited January 2006
    1812. End thread. :p
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    edited January 2006
    kmartin971 wrote:
    Early B:
    Well, not early B but I am sure you would hear the following....
    SVS (almost a cult following, great subs for the cash spent - typicallly HUGE though with med. to low WAF (but killer lows))
    HSU - would work fine in your size room. Very nice subs. (get a couple if in doubt)
    If size and looks are important there are more than a few small subs that sound good to choose from. Like with anything else, you pay for the size though - higher dollar / performance ratio, but they do look cool. - look at Sunfire, and some of the paradigms.
    I have heard decent things about the new polk LSi Sub, but just from specs I would put it more for music than movies.
    Michael
Welcome!
Welcome!
