HK AvR 335 bass mgmt
Willow
Willow Posts: 11,241
Does anyone know if the HK has a filtered sub out or a non filtered ?
Refering to the 335.
Post edited by Willow on
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    Not sure what you mean by that Willow. I know it has a sub-out with multiple crossover settings- 40, 60, 80, 100, 120, 150 & 200hz respectively.
    i hope that helps.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • drew spelts
    drew spelts Posts: 310
    edited January 2006
    I have the HK AVR635 and it does the same as andrew has posted. I connected my sub that I just built from LFE jack on the back of my plate amp to the sub-out one the back of the AVR. Works absolutely fantastic for me.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • John K.
    John K. Posts: 822
    edited January 2006
    Willow, for the 335(or any other receiver)to send a limited frequency to the sub, rather than the full range, it has to apply a filter set to the various crossover frequencies offered.
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    I want to get this receiver as well, from the reviews I have read each channel has a different crossover frequency you set and then sends the rest to LFE. Even for each input you have to reset the crossover for each channel. I have heard some say it is tedious and you have to read the manual to understand how to do it which takes some time, btu you gotta respect a product with that much bass mgmt capability.
    Do you like the 335 so far? What receiver did you have before it if any? How does the sound compare?
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • Willow
    edited January 2006
    You can see some of my initial thoughts in the electronics section
