HK AvR 335 bass mgmt
Willow
Does anyone know if the HK has a filtered sub out or a non filtered ?
Refering to the 335.
Post edited by Willow on
Not sure what you mean by that Willow. I know it has a sub-out with multiple crossover settings- 40, 60, 80, 100, 120, 150 & 200hz respectively.
i hope that helps. -
I have the HK AVR635 and it does the same as andrew has posted. I connected my sub that I just built from LFE jack on the back of my plate amp to the sub-out one the back of the AVR. Works absolutely fantastic for me.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
Willow, for the 335(or any other receiver)to send a limited frequency to the sub, rather than the full range, it has to apply a filter set to the various crossover frequencies offered.
I want to get this receiver as well, from the reviews I have read each channel has a different crossover frequency you set and then sends the rest to LFE. Even for each input you have to reset the crossover for each channel. I have heard some say it is tedious and you have to read the manual to understand how to do it which takes some time, btu you gotta respect a product with that much bass mgmt capability.
Do you like the 335 so far? What receiver did you have before it if any? How does the sound compare?-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Polk FXi3's Surround
Cerwin Vega HTS10 Subwoofer
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR -
StopherJJ1980 wrote:Do you like the 335 so far? What receiver did you have before it if any? How does the sound compare?
You can see some of my initial thoughts in the electronics section
