Matching center for RTi70's
snowjay
snowjay Posts: 7
edited January 2006 in Speakers
I have a pair of RTi70's teamed up with a PSW404. What would be a good center speaker match? It used to be the CSi30, which I guess is the current CSi3, or at least that had the closest specs.
Any other suggestions? How about a CSi5? or is there a wall mount that I could even use?
Post edited by snowjay on
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2006
    The csi40 and csi30 are matched to Rti70's but you could use a Csi3 or Csi5.
  • bobman1235
    bobman1235 Posts: 10,822
    edited January 2006
    The new series (Csi3 / Csi5) have different tweeters, I believe, than the Csi30/Csi40's do, so your best bet is finding a 30 or 40 on eBay or here, if you want a good match.
  • snowjay
    snowjay Posts: 7
    edited January 2006
    Ok thanks. The CSi30s seem to be hard to come by these days so I was just wondering. I'll keep looking.
  • snowjay
    snowjay Posts: 7
    edited January 2006
    I was just going over all the specs of the CSi30/40 and comparing them to the CSi3/5 and they all appear to have Silk/polymer tweeters.
