Avia Disk
fab5valentine
fab5valentine Posts: 84
edited January 2006 in Speakers
Where can I find a set-up DVD locally? And is it really as easy as just a few minutes to get things calibrated? Works for your sub too? I have already purchased a RadShak slp.. Just need a disk..
fab5valentine
-fab5
Klipsch RB81's/RC62/RS52's
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Toshiba 56MX195 1080p
Post edited by fab5valentine on
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2006
    A calibration disc is not manditory. Your test tones from your receiver/preamp will be more than adequate. If you really want the AVIA disc, yellow pages. Call your local A/V stores or the places where you get your CD/DVD's.
    FYI, The Sound & Vision Magazine Home Theater Tune-Up DVD is also produced by OVATION, they make the AVIA Disc.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2006
    I got mine on Ebay.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    You can use a bitcomet torrent client from bitcomet.com to download the AVIA disc torrent at torrentspy.com. Not that I would condone such activity and nor would I ever do it myself *wink* Then you can burn it with a DVD burner if you have one.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • fab5valentine
    edited January 2006
    As always, thanks.. I will get one soon.. To use test tones with an SLP meter is there a particular volume to use?? Can anyoneone be so kind as to give me a quick HOW TO.. My AVR will go below -O- (Denon 2802)..
    -fab5
    -fab5
    SVS PB12+/2
    Denon 3808CI
    Panasonic BD60
    billbillw Posts: 7,555
    edited January 2006
    Amazon sells it and ships quickly. That's where I got mine. I would recommend setting everything to 75db for home use. Don't worry about what the receiver volume control says, just adjust the different levels to match.
  • fab5valentine
    edited January 2006
    PERFECT!! Thank you!
    -Fab5
    -fab5
    SVS PB12+/2
    Denon 3808CI
    Panasonic BD60
  • Frank Z
    edited January 2006
  • Willow
    Willow Posts: 11,233
    edited January 2006
    This is great until you try to calibrate the TV without the filters. If you are going to calibrate speakers only then you'll be fine.
    I prefer the test tones in Avia but I don't like the hosts. I like VE , I find it a bit easier to navigate.
