Dual Rti8 question
I was wondering if it was possible to run 4 rti6's as mains. One on top of the other and jump a connection from one to the other?
Post edited by Jer_ry on
That will lower your resistance to 4ohms. If your amp can handle it, you're fine.
Forget about it. Just buy some floorstanders.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
PolkThug wrote:That will lower your resistance to 4ohms. If your amp can handle it, you're fine.
considering those speakers can go down to about 4 ohms during normal use, having them in parallel would mean his amp would be seeing 2 ohms. Bad idea!!
Just use a 5 channel receiver and connect them to the FL, FR, RL, and RR outlets and use 5 channel stereo.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
As long as his amp can handle a 4 ohm load it should be fine. Most 4 and 6 ohm speakers can dip that low anyways, so if his receiver can handle a regular 4 ohm speaker it should be okay. Not sure if it'll sound any good but that's a different question
If you do do it make sure to flip the top one upside down so that the tweeters are closer together helping with any phase issues that might occur... -
michael_w wrote:As long as his amp can handle a 4 ohm load it should be fine. Most 4 and 6 ohm speakers can dip that low anyways, so if his receiver can handle a regular 4 ohm speaker it should be okay. Not sure if it'll sound any good but that's a different question
flip an rti8 upside down?KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
I think it was a typo in the thread title...Jer_ry wrote:possible to run 4 rti6's as mains. -
Now that I think about it, for the amount of improvement in sound quality you'll get (not much) by using two pairs of RTi6's you could get a much nicer speaker with that extra cash thrown towards the extra pair. Check out some other speakers in the price range of two pairs of RTi6's before you go ahead and blow the cash.
michael_w wrote:I think it was a typo in the thread title...
I think you're right! :eek:KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Wow i didnt even relize that. Incase you already didnt know yeah i meant twin 6's NOT 8's. I am going to get 6's for my mains with my csi3 and every now and then you can get a really good deal on ebay for 6's. Since i would already have a pair didnt know if it would be a good idea to snag another pair and stack em for a cost efficient upgrade! Not sure about ohm's and all that but it would have been on a HK avr435.
You aren't going to add any quality. It's going to sound louder but other then that you won't get diddly. A couple of nice speakers don';t sound good as 1 great speaker. Save your cash and upgrade something better in your system.
