Dual Rti8 question
edited January 2006 in Speakers
I was wondering if it was possible to run 4 rti6's as mains. One on top of the other and jump a connection from one to the other?
Post edited by Jer_ry on
Welcome!
    edited January 2006
    That will lower your resistance to 4ohms. If your amp can handle it, you're fine.
    edited January 2006
    Forget about it. Just buy some floorstanders.
    "God grooves with tubes."
    edited January 2006
    considering those speakers can go down to about 4 ohms during normal use, having them in parallel would mean his amp would be seeing 2 ohms. Bad idea!!
    Just use a 5 channel receiver and connect them to the FL, FR, RL, and RR outlets and use 5 channel stereo.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
    edited January 2006
    As long as his amp can handle a 4 ohm load it should be fine. Most 4 and 6 ohm speakers can dip that low anyways, so if his receiver can handle a regular 4 ohm speaker it should be okay. Not sure if it'll sound any good but that's a different question ;)
    If you do do it make sure to flip the top one upside down so that the tweeters are closer together helping with any phase issues that might occur...
    edited January 2006
    flip an rti8 upside down?
    edited January 2006
    I think it was a typo in the thread title...
    edited January 2006
    Now that I think about it, for the amount of improvement in sound quality you'll get (not much) by using two pairs of RTi6's you could get a much nicer speaker with that extra cash thrown towards the extra pair. Check out some other speakers in the price range of two pairs of RTi6's before you go ahead and blow the cash.
    edited January 2006
    I think you're right! :eek:
    edited January 2006
    Wow i didnt even relize that. Incase you already didnt know yeah i meant twin 6's NOT 8's. I am going to get 6's for my mains with my csi3 and every now and then you can get a really good deal on ebay for 6's. Since i would already have a pair didnt know if it would be a good idea to snag another pair and stack em for a cost efficient upgrade! Not sure about ohm's and all that but it would have been on a HK avr435.
    edited January 2006
    You aren't going to add any quality. It's going to sound louder but other then that you won't get diddly. A couple of nice speakers don';t sound good as 1 great speaker. Save your cash and upgrade something better in your system.
Welcome!
Welcome!
