WTB: Mid-Bass Driver Monitor 5b
MrBuhl
MrBuhl Posts: 2,419
edited December 2005 in Wanted (WTB) Classifieds
Greeting Polksters!
Upon further review - it appears that I have a burned MB driver in my new 5b's on one side (I already swapped drivers so I know it's the driver not the crossover). So I have a couple questions hopefully someone can help me with...
1. Do I need to replace them as a set or can I just do one?
2. Anyone have a spare one they want to part with?
3. I don't see replacement drivers on the Polk Site specifically for this driver, do I just call and give them my speaker part number for replacement? I understand it should run about $48?
Thanks for any/all assistance - hope everyone had a great holiday! (I recieved a Csi3 Center as top gift!!) :D
Ed
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Post edited by MrBuhl on
  • janmike
    janmike Posts: 6,146
    Many people have called Polk directly and they tell you what you need, how much and send it to you. I have dealt with Polk in Canada and they are great people. I would give them a call.
    Michael ;)
    NORTH of 60°
  • MrBuhl
    MrBuhl Posts: 2,419
    Thanks Michael - that's what I figured but I thought I would float the idea of a used one as well...
    Also - is it OK to just replace the one or should they be both done at the same time?
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • burdette
    burdette Posts: 1,194
    What is the specific model number of the driver you need?
    I may have one. I probably do NOT, but I may, and I'll check.
    Send me an email rather than reply here. I'm more likely to catch that and check for you.
