WTB: Mid-Bass Driver Monitor 5b
MrBuhl
Greeting Polksters!
Upon further review - it appears that I have a burned MB driver in my new 5b's on one side (I already swapped drivers so I know it's the driver not the crossover). So I have a couple questions hopefully someone can help me with...
1. Do I need to replace them as a set or can I just do one?
2. Anyone have a spare one they want to part with?
3. I don't see replacement drivers on the Polk Site specifically for this driver, do I just call and give them my speaker part number for replacement? I understand it should run about $48?
Thanks for any/all assistance - hope everyone had a great holiday! (I recieved a Csi3 Center as top gift!!)
Ed
Ed
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Post edited by MrBuhl on
Many people have called Polk directly and they tell you what you need, how much and send it to you. I have dealt with Polk in Canada and they are great people. I would give them a call.Michael
NORTH of 60° -
Thanks Michael - that's what I figured but I thought I would float the idea of a used one as well...
Also - is it OK to just replace the one or should they be both done at the same time?VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
What is the specific model number of the driver you need?
I may have one. I probably do NOT, but I may, and I'll check.
Send me an email rather than reply here. I'm more likely to catch that and check for you.
